  • 4 months later...
  • Replies 48
so this just passed the 1 year in the shed mark
and i have been plugging away at small things trying to make sure it all fits
made a cut down sump using the bowl of another sump ... it was ugly welding and looked too small on capacity and leaked like a sieve
so i made mk II version deeper and with new 2mm steel much easier to deal with made 1 flat plate right thru at cut line and then made the cutout and bowl for ford v8 pickup
very minor weeps on testing and i just hit it with the full POR tank sealer system to sort that out
oil filter remote and oil cooler mounted and plumbing mocked up
lots of little bits to sort so they dont try to occupy the same space under the bonnet
  • 3 months later...
engine mounts welded and fitted to spare block
silly non used egr plate trimmed back for critical room around the rear of rh head /firewall interference area before pic
After trimming
  • 3 months later...
Sub glacial speed progress ... avoiding the wiring nightmare
made a thing for oil filter take off to clear exhaust and alternator
hand carved from 10mm alloy tapped for the tightest 90deg an10s I could find
Wiring nightmares ...
removed everything I didn't need and maybe too much
Mazda seemed to make every part of the harness run thru every part of the car and back again ... all I have working at the moment is headlights indicators and heater fan ... popup headlights no go no tail or park lights
very tempted to just remove everything completely and just keep the tail loom and start from scratch with a universal fuse/relay box
bright spark ideas anyone ?
Fuck it ... removed eeeeverything back to the switches and light plugs
cmon Mazda we know you were improving the classic British roadster but you could have not copied the Lucas parts
oh well engine bay will be tidier
Progress report ... still avoiding wiring ...
scored some better carpet and installed a set of PRD frame rail braces while the interior is gutted to cover my bashed in frame rails
and installed some Chynamatt sound and heat insulation
no rust in the floor was a bonus
  • 2 years later...
Long overdue update now with added shed hoist and coronavirus
bought a new mig and spoolgun and attacked welding a new mount for starter onto bellhoising - seemed to work ok used 10mm alloy plate and there are 2 bolts that capture it right thru to the block - no photos but it looks factory - starter mounted and engagement checked many times
threw motor and box back in again - love this put engine on crane and then just lift car on hoist under it
got very bored during lockdown even working some days
so small steps one wire at a time - made a big fat new earth wire for battery - and better terminal on positive lead and reattached lead along the pppf frame to the starter
new wire from starter positive to alternator output and new wire from there off to start of new fuse box
clipped a wire onto starter solenoid filled engine with oil and removed spark plugs that were sitting in loose and turned it over with socket on the crank pulley for a bit
touch starter wire to positive fuse terminal and we have turnover yay
was not sure if I was gonna have to prime oil pump after sitting so long with no sump on and being upside down and stood on its nose quite a bit but had a gusher from my oil filter adaptor right away
stopped attached hose for filter and oil cooler then turned it over till solid oil out of the return hose then reattached that
if I can make and fit 1 wire per day it’s progress
Blah blah wall of text - photos
Other stuff I have done then forgotten about
removed the stupid cooling hose that runs from front of the heads to the back between the V to the thermostat
bought a Davies Craig electric pump and gutted the water pump to feed inlet water in thru there and return back thru the stock water outlet at front of heads - ecu will have control of pump
got main throttle cable sorted and mounted and double return springs bought
runs a crossover cable between the two banks of throttle bodies - will I need 2 sets of double springs ??? ( each ITB has its own spring on butterfly also)
Stuff on the list to cross off ...
wiring .... ecu and get the motor running first then body wiring
fit rx7 Flexi clutch hose and bleed / check clutch engagement
refit rear brake lines and bleed - has all new pads rotors in the bigger nb size
fit new polybushes front and paint front arms
Refit dash and seats and centre console delete
test hoon round section in ever increasing laps
go for a bigger test hoon and see about an alignment and fail a warrant
find somewhere for cert as closest was Nelson /mot but no longer cert guys there which is gonna be a pain - build trailer may be an option
46 minutes ago, yoeddynz said:
I spoke to Barry dowler not that long ago and he was still doing certs.
Cool I need to give him a call sometime - would be so much easier in mot
  • 3 months later...
4 hours ago, ~Slideways~ said:
Man this is so cool, the engine fits in there so nicely. It'll sound awesome with those ITB and the already cool K exhaust note.
ps...wanna trace the adapter? haha
If I have to take the gearbox off again I will do a trace of adaptor -but if I was doing this again I would follow the path Hurmeez on here went and go six Spd rx8 Aisin gearbox and flywheel adapter onto rx flywheel and clutch - just looks so much easier and cleaner and then runs stock parts for clutch and starter
Bought a new Link Atom G4X ecu and loom and been studying up on link forum and HPa academy
 Bought decent crimpers and new terminals and connectors
found a Toyota coil on plug that fits the engine ( Yaris coils are too fat) and made some mounts to hold them down and wired ignition loom
  • 10 months later...
Been a while - it’s been exhausting ... built some very dodgy 3-1 headers to fit thru the incredibly small gap between motor and front subframe - down into a pair of flexys and then 2-1 was aiming for a crossover and twin pipes to the back but nope not enough room thru rear subframe - wideband goes in the top of the 2-1 join then piped to one big muffler at the back
Needs to come back out for a tickle up and paint then I’m gonna call the exhaust done
