20v 4AGTE intake opinions
LingLong
Hey guys! Im new to the forum and working on cars in general. My AE86 Levin has recently been stolen and luckily recovered. Anyway, a rebuild is being planned and I am wanting to use this time to upgrade bits and pieces etc. Something that has been on my list is to upgrade the current intake setup as it can definitely be improved upon. Currently a 20v head with itbs and crude plenum.
My question for you experienced 4AGTE folk is, do I keep the itb setup and get a new plenum, or do I ditch itbs and go for a single throttle? For my build I am aiming for good response and a decent power range, Im not looking for big top end power numbers and would rather have more useable power throughout.
I would like to know with peoples experience the pros and cons of either itb or single tb?
To keep the itb setup would probably be cheaper and easier as all i have to do is bolt another one on. But in the long run is tuning and maintaining an itb setup a big hassle? I seem to hear that they are touchy and high maintenance but can pay off if you are after that little bit more performance.
If I were to go single throttle I would probably just bite the bullet and get an MRP plenum which is pricey, plus extra expenses of top feed injectors and whatever else is needed. Will this be a lower maintenance setup, can it perform better than itbs? who knows? Not me!!!
Engine bay pic     https://www.instagram.com/p/BF78vdrnMcc/?taken-by=ken_ola_oil&hl=en
Stick with the itb's.   will have to be a pretty good single throttle setup, to make any gains over the stock setup.
have the benefit of being able to move the power around by changing trumpet length on itb setup
I am running a gtir plenum with a laser cut adapter plate to suit the 20v. Havent run it yet but seems like a few guys have done it. looks quite tidy and factory as well. Heres a picture of someone thats done it because i couldnt be bothered uploading mine haha.
chap at work has indeed just done an intake using gtir plenum cover.
worked out pretty good, unless you plan on messing around with trumpet lengths, as i dont think there is room at the rear.
But If I was building one, I would do the same mod I would say
Thanks for your replies, It looks like sticking with the itb setup seems to be the most practical but I am still considering a single throttle, I must admit I think stb looks much cleaner. I am wondering if anyone has any experience with running both itb and stb on their turbo setups? was there really any noticeable difference between the two?? I guess a comparison would be between 16v 4age turbos vs 20v 4age turbos with itb. Although they are possibly quite different. Best inside info would be from someone who has run both itb and stb on the same setup!
Here is a fap pic of the possible single throttle setup I would possibly go for.. So clean, love how beefy it looks too
https://www.instagram.com/p/BF-mscnnMVM/?taken-by=ken_ola_oil
I am curious if, (with single throttle) on throttle and off throttle response is really going to be affected noticeably at 14 psi of boost and high rpm engine braking. Are there any calculators I can use to see what the actual difference in time there will be to fill and consume the volume of a larger single throttle plenum. If it is some tiny amount of time then I would consider the benefit of itb response to be negligible!
Another fiscal question... Would the sound of the engine change if I went stb? Just curious!
I have been hunting around on RB26 forums but they seem to be hunting for big power, not many people talking about street/circuit applications and nobody seems to have a direct comparison of both.
The time difference of response is bugger all.
As an example.
A 2000cc 4cyl 4 stroke engine (if non turbo and 100% VE) inhales 1000 litres of air per 1000rpm.
So 7000rpm = 7000litres per minute.
2 litre plenum = under 20 milliseconds to empty.
A 20 litre plenum, which would be rediculous, (size of 10 milk bottles stuffed in your engine bay somewhere) would still only be 200 milliseconds.
A 1.6 litre engine will be 0.8x the times listed above.
Human reaction time if you're wired on coffee is just under 1/3rd of a second, (300 milliseconds).
You're not going to notice any difference in sound, because all of the sound waves are happening between the plenum and turbo outlet rather than exposed to atmosphere with NA car.
Single throttle will be easier to tune as you get a more stable MAP signal, personally if I was going ITB turbo I would fit a MAF Sensor if off boost drivability etc is of concern.
Why not check out the sr20 forums. They use single and quad throttles on the same basic motor and I bet you can find heaps of threads about it.
As David has said- the time taken to empty the plenum is SFA...but even if it WAS a significant difference, who cares. Ditto with the engine sound thing. Once the motors running you won't care two shits what it comparatively sounds like.
Basically, don't end up like ME stressing over numbers on a piece of paper. It's a downward spiral into huge unfinished project territory and I owuldnt wish it upon anyone :-D
Just run with what you want it to look like - there's very little in it.  If you like the look of a single and have the money to buy one or time to make one, go for it.  If you want to keep the quads then just get a new plenum as your current one needs to be run over by a bus.
Changing the turbo will have more of an effect than changing the inlet.
I think everyone is on the money. Ive been nutting it out way too much haha. Im just gonna do whats easiest and most cost effcetive for me atm and keep the itbs. Some good advice from everyone. Time to get on with it
