Last bits of tube bending done on fuel system
For the vent, I've run a nylon tube up the pillar across the top and back down the other side. Wasn't too sure on the industry best practice with fuel tank venting. This should be OK I hope
Not too keen on the colour of these fittings, reckon they look out of place.. should of got black ones I suppose
Cooling system is pretty much sorted. I've kept it really simple, no heater etc. Only one line returning from the back of the head. Have decided to ditch the idea of running factory oil cooler, so I plugged that hole in the block. This motor was already setup to run without it. Looks like a restriction anyway.
Welder had a hard time with this. Quite shite material apparently. Couple pin hole leaks unfortunately, should be easy fix though
And then theres this.. pretty tight fit. Won't come off now. I'll put this adapter in if it proves unreliable being so stretched like that.
New page would be good
