MRWEST Posted April 18, 2016 Share Posted April 18, 2016 Failed a cert on brakelines not being shielded within 100mm of headers/exhaust on the Impala. The lines are run on the factory route however along the top of the chassis rail. But anyway need to find someway to shield it, My main requirement is want something that looks tidy as the engine bay is tidy. Thoughts? Quote Link to comment Share on other sites More sharing options...
tortron Posted April 18, 2016 Share Posted April 18, 2016 Machine some circles into some alloy sheet with a wire brush on a drill. Very 60's custom Quote Link to comment Share on other sites More sharing options...
Roman Posted April 18, 2016 Share Posted April 18, 2016 Is there shiny stuff in your engine bay? A polished up sheet of very thin stainless works well, just need an air gap between hot side and cold side. (Dont have it hard up against one thing or the other) But hard to say whether that's suitable without pics of where it needs to go. If you really want a clean looking engine bay then remaking the brake hard line might be the best option. Quote Link to comment Share on other sites More sharing options...
tortron Posted April 18, 2016 Share Posted April 18, 2016 White padded leather would also be acceptable, as long as you pad the wheel wells too 3 Quote Link to comment Share on other sites More sharing options...
MRWEST Posted April 18, 2016 Author Share Posted April 18, 2016 Engine bay below, They do run close along the headers, but remaking them probably isnt really that easy/possible without going up under front guard or something? Quote Link to comment Share on other sites More sharing options...
MRWEST Posted April 18, 2016 Author Share Posted April 18, 2016 Probably need to get a better pic tonight of the route along the side of the headers Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 18, 2016 Share Posted April 18, 2016 yeah this is common. worst case make something that works for a cert and remove afterward But, that is not ideal really, as the idea is that they are meant to work. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 18, 2016 Share Posted April 18, 2016 Could you coat the exhaust in ceramic coating (HPC) or alternatively header wrap? Quote Link to comment Share on other sites More sharing options...
bigmatt4 Posted April 18, 2016 Share Posted April 18, 2016 http://www.autozone.com/ignition/heat-shield-sleeve/thermo-tec-1-4-to-1-2-in-i-d-x-7-16-in-o-d-x-12-ft-thermo-sleeve/398816_0_0/?checkfit=true how about this sort of stuff Quote Link to comment Share on other sites More sharing options...
MRWEST Posted April 19, 2016 Author Share Posted April 19, 2016 Could you coat the exhaust in ceramic coating (HPC) or alternatively header wrap? Yes i could but gone to the expense of buying stainless headers/exhaust dont really want to cover them in heat shield haha http://www.autozone.com/ignition/heat-shield-sleeve/thermo-tec-1-4-to-1-2-in-i-d-x-7-16-in-o-d-x-12-ft-thermo-sleeve/398816_0_0/?checkfit=true how about this sort of stuff Could work yeah, would need to check with cert guy i guess? Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 19, 2016 Share Posted April 19, 2016 Could you not just get a nice little length of s/s cut and bend up to go over top of the brake line in the affected area? Quote Link to comment Share on other sites More sharing options...
