Leoyce Posted December 7, 2015 Posted December 7, 2015 (edited) Hey Everyone, (Project Thread) Here's my baby. Now, I wonder if anyone can help? The seller says the car's a GSR but since she hasn't been very honest, I'm having my doubts...(then again she could be misinformed and very oblivious) All the car really has to associate him with a GSR is his bolt-ons but these could have easily been fitted. He has no identifying badges. They were thrown out with the original grille. He has no GSR seats. Was told the front were swapped (one's green, the other's brown. Thought only one might have been replaced but none match the colour of the back seat and interior, which is black). No mention of the back seat being changed but it has a different pattern to the GSRs that I have seen online (eg. 1, 2 ). Also, the back side panel is different. Mine has a debossed GT in the back and a metal strip above the ridges. I don't see that in this GSR. Lastly, his chassis number starts with A57C - 39O (A57C - 39O1176) where the 75 GSRs on goo-net-exchange (eg. 1, 2) start with A57C - 371. In saying that, I did find a 4g52 motor for sale that says it's Grade GTO GSR and it's body number is A57C - 3903332. Unsure how reliable it is since the seller does not know the year or model. (Anyone know how to read the chassis number? Contacted Mitsubishi about it but haven't heard back yet) I'm not really fussed either way but it would be good to know what I have. Edit: Added Project link. Changed for readability. Added and edited info. Changed title (we think it's actually a 73 not a 75 model. Will change back if Mitsubishi says otherwise). Edited December 8, 2015 by Leoyce Quote
kyteler Posted December 7, 2015 Posted December 7, 2015 Cripes, bit of work there, chap. Hopefully the important part, the steel-work, is still legit. Quote
Leoyce Posted December 7, 2015 Author Posted December 7, 2015 Haha, true! Wanting to strip it down in the next couple weeks or so but really depends on how much time I have. Fingers crossed there won't be any nasties Quote
MichaelJFox Posted December 7, 2015 Posted December 7, 2015 Some of those photos scare me. Best of luck dude! 2 Quote
ajg193 Posted December 7, 2015 Posted December 7, 2015 Bigfoot is into mitsi's, he may be able to help you Quote
DriveBy Posted December 7, 2015 Posted December 7, 2015 Check out this link. http://www.galantgto.net/number.html Has chassis numbers for various models. Yours appears to be a GSR but 1973. Has the corresponding early engine too (dizzy is out the head = early 4g52). What's it registered as on Carjam? I have a couple of GS models and those chassis numbers are accurate for those. Quote
Dell'orto Posted December 7, 2015 Posted December 7, 2015 Pretty rough, but it looks to be reasonably complete at least. Congrats on finding one Quote
MaxPower Posted December 7, 2015 Posted December 7, 2015 be careful pulling the rubber off that runs along the top of the glass below the gutter. hard to find and buy.. will be hard to find all the correct gsr bits but good luck. Quote
dwlee Posted December 7, 2015 Posted December 7, 2015 Looks like you've got a lot of work ahead of you. I'm sure DriveBy meant dizzy driven by the crank in the early 4g52. The later engine have the dizzy out of the head and have balance shafts. Under the rear flares have the original metal flare been cut away and the inner and outer skins been spot welded together like in this photo http://homepages.paradise.net.nz/mitsubishicarclub/photoGTO1976RebeccaShaneReckin.jpg? Your front guards will be different being a 73 unlike the late 75 in the photo, but the cut away rear will confirm if its a GSR. The original flares will be plastic with the correct position in raised lettering on the inside surface and have five bolt holes. Looking at the photos the front flares aren't original and if the rear left is original it should be on the right not the left. The tacho is from an earlier GTO with a 4g32 engine as the red line is wrong for the 4g52 where the red starts at 6000rpm even through max power was at 6200rpm. Quote
DriveBy Posted December 8, 2015 Posted December 8, 2015 I'm sure DriveBy meant dizzy driven by the crank in the early 4g52. The later engine have the dizzy out of the head and have balance shafts. Whoops my bad yes. The earlier engine is considered a better engine by all accounts. Quote
Leoyce Posted December 8, 2015 Author Posted December 8, 2015 @MichaelJFox Thanks Mate @ajg193 Cheers for that, really appreciate it. Though I think DriveBy and dwlee pretty much have it sorted. Will keep him in mind for the future though @DriveBy Mate, you are awesome I tried searching chassis / vin number, didn't even think of trying serial numbers...No wonder I didn't find anything. So my car's a 73 model, makes sense why it never matched up to any of the 75s I was comparing it to lol I did search my plates on Car Jam and they say it's a 75 (very first registration was in New Zealand on 03-06-75). Still, I'm more inclined to believe you as it won't be the first time Car Jam has gotten something wrong. Will let you know what Mitsubishi says when they get back to me. @Dell'orto Mmmm, wasn't what I was promised but still happy to have the car. @MaxPower Thanks Mate but they're pretty shot anyway. Definitely going to need new ones...Have been searching around for parts but yeah, it's a killer @dwlee Ahh, I was waiting for you to show up as I had a feeling you would know Checked the rear metal flares and they have been cutaway and spot welded like you said. Rear bolt-on flares are plastic and do have five bolt holes. Couldn't find the raised lettering but will have another look when I get them off the car. Also, do I need to swap them around? You said the rear left should be on the right (side) not the left. Did I understand that properly? While I was at it I checked the front right guard too and it had holes where the original flare was. Didn't bother with the other side as that whole panel was replaced after an accident. Probably the reason for the after-market flares... Thanks for the info on the engine too. Be good to have when I sell it. Quote
dwlee Posted December 8, 2015 Posted December 8, 2015 The raised lettering should look the image below with this one being from the front right. Yes you understood what I was trying to say. The little cut backs at the base of each flare should be pointing towards the door for both front and rear. Hopefully the image below should help explain . Quote
P_Star Posted December 9, 2015 Posted December 9, 2015 This might be useful... looks pretty straight, heaps of spares, cheap as balls? http://www.trademe.co.nz/motors/used-cars/mitsubishi/auction-996145332.htm Quote
Leoyce Posted December 9, 2015 Author Posted December 9, 2015 (edited) @dwlee Mate, you are the Man Thanks for going through the trouble of posting pics, really helped! @P_Star Cheers Mate, appreciate it Tried to call the guy but he's not answering, maybe he's already asleep? Left a text and email, really hoping he gets back to me before anyone else calls him. I BAGS IT!!!! Lol, if only that worked... Edit: Missed out guys. Just tried him again and someone's already bought it (was it you @Drakes?) Usually I check Trade Me in the morning and after lunch but of all the days, I had to pick today to wait until tonight... :cry: Edited December 9, 2015 by Leoyce Quote
P_Star Posted December 9, 2015 Posted December 9, 2015 Bugger! I figured it wouldn't stick around, was CHEAP!!!! Hopefully someone on here grabbed it Quote
Leoyce Posted December 9, 2015 Author Posted December 9, 2015 Yeah, couldn't believe how cheap it was actually. Probably moving to Australia pretty soon so just wanted it gone. Mmm, I'm hoping someone did a Threeonthetree and I'll get a PM saying 'Leoyce, I bought the GTO off Trade Me just to save it. You can have it for what I paid' lol I bought all three bicycles. MJF you can have them for what I paid, I only grabbed them all to save them. 1 Quote
Hitchy Posted December 9, 2015 Posted December 9, 2015 S$&&' I just saw that one and emailed him cause it to late to ring. Then come on here and find out he sold it. Am going to Welly for AC/DC on sat as well. I thought it was xmas. Now. I'm. Shattered. Quote
Leoyce Posted December 9, 2015 Author Posted December 9, 2015 (edited) You know, I thought if it wasn't Drakes, it might be you who bought it. Yeah, I was the same. Saw the listing and was like IT'S MINE!!! lol Pretty guttering to find it's already gone... Haaaah, there's just too many of us needing parts Edit: Thought I'd clarify in case this was misconstrued. I'm not upset that I have to compete with others for parts. It's just sad that there's so many of us who need them but so little to go around. Edited December 9, 2015 by Leoyce Quote
