dwlee
    Auckland
dwlee's Achievements
Advanced Member
Advanced Member (3/5)
36
  1. Yes, shimmed spring can reduce the lift potential. The binding length stays the same. You just have to make sure the compressed height at full lift is above the coil bind height with a bit of margin for safety.
  2. Yes, shimmed to give get your desired height.
  3. The specs are just for the springs, not how they are installed. With an install spring height of 41mm they generate 90lbs of force and when compressed by 11mm (spring height 30mm)the generate 225lbs of force. This gives a spring rate of (225-90)/11mm = 12.27 lbs/mm. Lets say, for example, you install the springs with a height of 38mm, you will have a seat force of 126.8lbs. The valve lift from the cam datasheet is 0.363" (9.22mm). So at max lift the spring will be generating 240lbs of force. At 9.22mm lift and install height of 38mm the spring length will be 28.78mm, which is above the coil bind height of 26.5mm. If you want 160lbs of seat force with those springs the install height would need to be 35.3mm, but then the spring height at max lift would be 26mm and you would have coil bind. I think you should be asking Kelford what the install seat force should be for your application (30psi boost on a 44.2mm valve). Other useful information that may be helpful in getting a better answer is the standard spring install height on a 4ZE1 open chamber head and max rpm you intend to use.
  4. Sorry Tom, I couldn't find the shroud. It was from an early L200.
  5. I might have a shroud that may fit. I'll have a look in my stash and let you know.
  6. The standard leaf springs as pretty soft and if you have them reset you may need to add another leaf. I had to do this with the 76 and I'm likely to do it again with the 75. I'm using early land cruiser (Fj40) shocks in the rear.
  7. Looking good with the stripe. What do you want to do with the suspension? Just lower it a bit, replace bushings and shocks or are you wanting to go it further?
  8. Good luck with the wof. It's certainly looking great! I bet you can't wait to go for a drive on a hot day with all the windows down listening to the music from the carbs.
  9. The paint job looks great. I bet you can't wait to get it back on the road.
  10. Keep up the good work. The new carbs will sound fantastic.
  11. dwlee
    16L colt boot
    When I was looking for boot rubber for the GTO Basis were very helpful, but at that time (2012) they didn't have anything that fitted correctly. I ended up using the one from Scotts old auto rubber and did does the job pretty well, but it was tight until the rubber settled down.
  12. Have you watched the pattern making / prepreg vids yet as they are just as good.
  13. These guys have some good videos https://www.youtube.com/user/easycompositestv/
  14. Have you confirmed that the studs you have are correct for 4g63 mains as they should be m10 with 1.25 pitch. You may have 7bolt head studs, which are m11 x 1.25 pitch. Again what is the part number of the studs you do have?
  15. What is the part number of the ones you have? As far as I know the mains are near enough the same for sohc and dohc 6 or 7 bolt. RPW sell the same kit for them all http://shop.rpw.com.au/online-store/products-by-vehicle-manufacturer-2/mitsubishi/mitsubishi-starion-turbo/engine-products-starion-turbo-4g63/main-stud-kit-mitsubishi-4g63-detail.html but you are better dealing with Sta parts as it will be much cheaper http://www.staparts.co.nz/View-A-Product?id=401&Productid=Main stud kit Mitsubishi 2.0L 4G63 dohc 16 valve 2-bolt hex
