Mk1Daniel Posted October 6, 2014 Share Posted October 6, 2014 So I have a Mk1 Escort Coupe with an sr20det in it. The diff ratio sucks. goes like 80ks in 1st. Its a BorgWarner lsd out of a v8 falcon (apparently) Can I use the crownwheel and pinion out of this http://www.trademe.co.nz/motors/car-parts-accessories/holden/diffs-axles/auction-789203984.htm and keep the rest of the lsd gear?Havnt had a BorgWarner apart before and thought I might as well ask instead of fucking around just to see Quote Link to comment Share on other sites More sharing options...
ZOO222 Posted October 6, 2014 Share Posted October 6, 2014 If the diff you have is indeed a Borgwarner 78. Then yes you can change the crown wheel and pinion over to the LSD. This might helphttp://calaisturbo.com.au/showthread.php?t=155191 Quote Link to comment Share on other sites More sharing options...
Valiant Posted October 6, 2014 Share Posted October 6, 2014 You need to know a bit more about your diff. It should have what type it is stamped on the crown wheel you can see it if you take the back hat off. That VL diff will be a 75 series. it seems odd that it is a 4.11 to my knowledge the lowest ratio VL diff was 3.45. Quote Link to comment Share on other sites More sharing options...
Mk1Daniel Posted October 6, 2014 Author Share Posted October 6, 2014 Cheers mate. Yeah pretty sure it's a borgwarner Quote Link to comment Share on other sites More sharing options...
Valiant Posted October 6, 2014 Share Posted October 6, 2014 Good yeah but there is about 3 different types of Borg warner. 74/75 and 78. some bits interchange and some don't. Quote Link to comment Share on other sites More sharing options...
Mk1Daniel Posted October 6, 2014 Author Share Posted October 6, 2014 I have read that vls and r31s can have 4.11 but I don't know.. ok guess I'll have to pull it apart.. will it be on the tag? Mines broken off but I need to know what the vl one is Quote Link to comment Share on other sites More sharing options...
AllTorque Posted October 6, 2014 Share Posted October 6, 2014 See here for finding diff ratio //oldschool.co.nz/index.php?/topic/19944-how-to-tell-your-diff-ratio-without-taking-diff-apart/?view=getnewpost Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted October 7, 2014 Share Posted October 7, 2014 The BW model number is the diameter of the crownwheel in (tenths of) inches - 68 = 6.8", 75 = 7.5", 78 = 7.8" http://www.aussiev8.com.au/driveline-suspension/33590-diff-information-thread-basics-salisbury-borgwarner-bw78-ford-9-a.html 2.77:1 some Falcons (possibly Fairlanes), I have heard that these may require a different housing2.92:1 also Ford stuff3.08:1 standard on VN-VS V6 and V83.23:1 VK 1/2 injected six3.45:1 VL3.7:1 R31 Skyline manual3.89:1 R31 Skyline auto - dodgy according to most people, noisy and possibly failure prone3.91:1 R31 Skyline auto supersedes above4.11:1 R31 Pintara Quote Link to comment Share on other sites More sharing options...
kurtis1791 Posted October 7, 2014 Share Posted October 7, 2014 Rb20e auto vls were 4.11 oz didnt get them so dont know Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted October 8, 2014 Share Posted October 8, 2014 V8 Falcon should have a 28-spline 4-pinion BW78. According to this chart 4.11 VK/VL Commodore was 25-spline 2-pinion BW75 (VL Turbo and V8 got BW78). http://www.difflappingqld.com.au/uploads/web/gear-diff-ratios.pdf 1 Quote Link to comment Share on other sites More sharing options...
Mk1Daniel Posted October 8, 2014 Author Share Posted October 8, 2014 So basically no?? Who knows what will be a good option :/ Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 8, 2014 Share Posted October 8, 2014 The only option is to find out what you have to begin with. 2 Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted October 8, 2014 Share Posted October 8, 2014 Is the ID tag missing from the diff? Only way to be sure is to take the back cover off, measure the diameter of the crownwheel, count the number of teeth, and count the number of splines on the halfshafts. 1 Quote Link to comment Share on other sites More sharing options...
Mk1Daniel Posted October 18, 2014 Author Share Posted October 18, 2014 Yeah, you can see half its been ripped right off. Nothings ever simple with modified cars Quote Link to comment Share on other sites More sharing options...
EFI_LC Posted October 20, 2014 Share Posted October 20, 2014 Just to throw something out there, I have a BW 4.11:1 from a VN wagon 4 cylinder. Apparently they run ex VL diffs so that Holden could get rid of the excess they had. Quote Link to comment Share on other sites More sharing options...
