Everything posted by kurtis1791
Rb20e auto vls were 4.11 oz didnt get them so dont know
Yea thats the guide im using to build them from. Just that the size of my struts doesn't seem to be as easy to find tube for. Will try steel and tube tomorrow if I can. Anyone know which Wellington branch I should be going to?
Not yet. Need to finish work early one day to get in there
Hey guys Am at the point in making my coilovers that I need to get hold of some threaded tube My struts have an od of 54mm ish Where do I find some threaded tube to suit these? After searching I can find some that are 55mm offshore was hoping to find some locally. 55mm should be fine yea? cheers Kurt
30-40 psi should be fine. My commy when cold has max of 50 and drops down to about 8 when hot at idle.All within spec
Yea the axle and hub will be 1 piece. Take to an engineer to be redrilled 4 stud
Sweet its only ve steels that have the smaller bore.
Already have a widened set just need 2 more 15x7 as cant get 10s under gaurds. And the 16s have a smaller centre bore. Have 2x 15x6 I can swap + $$ for 7s
Any of your steel wheels happen to be ex police steels?
Dan?
Ill get you a price 2moro if you want?
- 8 replies
- noob saibot
- camaro
(and 2 more)
Tagged with:
Value tyres in petone sell the cheap chinese linglongs etc. Can get number tomorrow from work.
- 8 replies
- noob saibot
- camaro
(and 2 more)
Tagged with:
Hi im interested in purchasing this vehicle. http://www.trademe.co.nz/741247607 Is there someone local that could have a nosy at it? Let me know Cheers Kurt
Cool thanks
Hi. I am in the process of getting the bits together to make some adjustable struts as per seedy als guide in tech articles, quick question do they need to be tig welded for cert or is mig alright? And will they also need to be crack tested? Cheers Kurt
WTBorrow: Engine Lifter -Wellington wide.
kurtis1791 replied to thegreatestben's topic in Lower North Island Region
Got one in stokes valley you can use. 0274705473 -
Theres a place in upper hutt that a family friend just got some done and power coated for around $ 40 each for blasting and pc. Dont know the name but cant be to many places there.
rear diff housing arm bushes for ex lancer
kurtis1791 replied to ex lancer wat!'s topic in Tech Talk
When i had trouble with this just ended up buying a good set of 2nd hand arms as was to much hassle at the time to remove, measure match up or have some made. -
Hey guys need to get some fluoros and some powerpoints wired in to my garage. Anybody in Wellington able to do this as a cashy? I can either buy the stuff needed or have you supply it for me. Let me know. Cheers Kurt
Is it causing a problem? its obviously been like that for ages. Personally id leave it if was all working efficiently as is.
When I check for wofs you flick key on and engine off and wait for light to go out tho incase some clowns wired it up to oil pressure switch. won't go out till engines started and thats a dead giveaway its been dodgy'd up.
700 is what I paid so would like to get that for it. Is brand new
I have one of those manifolds. Redline hi winder if your after one?
Yea I think thats the way ill go. Over on the commodore forums they reckon factory computer is capable but ive been reading up on megasquirts and quite like that id be able to tune it myself which will be something new but am keen to learn and like that id be able to tidy up all the wiring with an aftermarket computer as well. Now does anybody know where I could get my manifold drilled for injectors? Preferably in Wellington Cheers Kurt
