AllTorque Posted June 30, 2014 Share Posted June 30, 2014 //oldschool.co.nz/index.php?/topic/44116-madbuzs-1200-sunny-truck/ This little truck is so awesome in real life. Nearly certed? Quote Link to comment Share on other sites More sharing options...
beachlander Posted June 30, 2014 Share Posted June 30, 2014 I love this thing. Hope you didnt have to raise it too much? Quote Link to comment Share on other sites More sharing options...
Beaver Posted June 30, 2014 Share Posted June 30, 2014 hot diggity this is lush. Good to hear you got the brakes sorted. Keen to have a yarn about your cert process at some stage (will probably end up using the same guy) and sing out if you need those wheels. Quote Link to comment Share on other sites More sharing options...
MADBUZ Posted June 30, 2014 Share Posted June 30, 2014 Yeah just need to make up a plate to suit new calipers tomorrow get them fitted up bleed brakes and should be all go. The brakes were a bit suspect that they would pull it up enough during cert brake test but now this has solved all my problems. Pretty much ready for recheck now. Although I'll need to do someone perkies to pay for it. Haha Quote Link to comment Share on other sites More sharing options...
MADBUZ Posted June 30, 2014 Share Posted June 30, 2014 Oh and raised it about 25mm which doesn't seem like a lot but when it was as low as it was it looks like a 4x4. How ever it should be close to the +\- 5% so as soon as I have cert and wof it's getting dropped again for sure. Will give you a good heads up for your wheels to Beaver. Thanks. Quote Link to comment Share on other sites More sharing options...
buzzy Posted June 30, 2014 Share Posted June 30, 2014 nice looking ute man! Good to see it's all coming together for cert. Out of curiosity why are they making you re-weld and crank test the coil overs? Â Quote Link to comment Share on other sites More sharing options...
MADBUZ Posted June 30, 2014 Share Posted June 30, 2014 The collar or spring platform was mig welded and needs to be a tig weld. And as it a suspension component it needs a crack test and documentation to prove that welding has been done to required spec. Quote Link to comment Share on other sites More sharing options...
buzzy Posted June 30, 2014 Share Posted June 30, 2014 oh yip, I have to cert my coupe soon so was just checking about the coil overs Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted July 2, 2014 Share Posted July 2, 2014 these brakes fit under 13s? Quote Link to comment Share on other sites More sharing options...
MADBUZ Posted July 2, 2014 Share Posted July 2, 2014 You know it! 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted July 6, 2014 Share Posted July 6, 2014 mean. what doing with old brake stuff? Â i need it. no point in upgrading my brakes when motor is pretty much standard Quote Link to comment Share on other sites More sharing options...
MADBUZ Posted July 6, 2014 Share Posted July 6, 2014 All yours. I think I even have a brand new set of pads somewhere too. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted July 7, 2014 Share Posted July 7, 2014 Wicked..will be in contact. Quote Link to comment Share on other sites More sharing options...
oldmatedan Posted July 7, 2014 Share Posted July 7, 2014 Grouse man The standard for sure Quote Link to comment Share on other sites More sharing options...
AllTorque Posted July 11, 2014 Author Share Posted July 11, 2014 How do you curb the inside of a wheel? Did those inners used to be outers? Quote Link to comment Share on other sites More sharing options...
MADBUZ Posted July 11, 2014 Share Posted July 11, 2014 Yeah I'm not sure. Was like that when I bought it. Can't see it when it's on car so doesn't bother me haha. Quote Link to comment Share on other sites More sharing options...
Bullitt Posted July 12, 2014 Share Posted July 12, 2014 One wheel on footpath and getting too far from the road? Quote Link to comment Share on other sites More sharing options...
MADBUZ Posted July 12, 2014 Share Posted July 12, 2014 I'd say that would be the case. Quote Link to comment Share on other sites More sharing options...
