gizzyguy Posted February 24, 2014 Share Posted February 24, 2014 hi all I am wanting to put a 308 into a holden ..has any one done it and can tell me what to expect?will a v8 diff go straight in ? will gearbox mount be the same?will I have to put bigger brakes in for a wof? Quote Link to comment Share on other sites More sharing options...
Corbie Posted February 24, 2014 Share Posted February 24, 2014 You might like to be more specific.. what model ute, whats in it at the moment etc. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 24, 2014 Share Posted February 24, 2014 H series Holden ute? A 308 will bolt up to the engine crossmember and gearbox mount should be the same providing you are using a factory Holden box. I swapped from a 202 to a 308 into my Commodore last year and even if I subtract the entire cost of fitting a Toyota gearbox then it still cost me well over $5K and that was with a sub $500 engine that I did not rebuild. V8 factory diff will bolt in. May have to change the driveshaft though, Overhauled factory brakes will be good enough for cert I am fairly sure. If I was to do it again I would look for a running 308 car with a fucked body and buy that then swap it over. It's all the little bits that add up quite quickly. I will chuck up a list of all the costs if you want as I kept a reasonably comprehensive record. 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 24, 2014 Share Posted February 24, 2014 Here is my list so far... Some of it you may not encounter but then again you may have more stuff you need instead. This adds up to ~$10K so far. Motor $350 Engine mounts $230 Engine mounts pt2 $70 Engine mounts pt2 $110 Starter motor $320 Cam and Lifters $180 Water pump $50 Oils and filters (run in) $120 Hoses $120 Radiator $400 Oil and filter $160 Electric Fan $30 Air filter $60 Carb overhaul $100 Inlet Manifold Repairs $120 Fuel pump $120 Exhaust Headers $380 Muffler and Diff Pipe $340 Bell housing $520 Flywheel and Bolts $290 Clutch $600 Release bearing $90 Gearbox $350 Drive shaft x 2 $450 Drive shaft Loops $150 Rear Trailing Arms $120 Front Suspension Bushes $250 Diff $350 Wheels $150 Spare wheel $40 4 x Tyres $200 Front brakes $400 Master cylinder $50 Cross member $60 Throttle bracket $60 Fan Shroud $250 PCV valve and fan belt $50 Fuel check valve $30 Degree Tape $15 Bonnet Pins $50 Alternator bracket $200 HT Lead Set $80 Gasket sets $150 Gasket goo etc $40 Wiring miscellany $100 Steel miscellany $50 Nuts and bolts $150 Speedometers bulbs $20 Exhaust and tuning $1,100 Speedo cable $50 Powder coating $40 Tyre Swaps $40 Make Batt. Leads $30 1 Quote Link to comment Share on other sites More sharing options...
danger Posted February 24, 2014 Share Posted February 24, 2014 Yeah can you be less vague? if its an H series ute it'll already have a V8/ salisbury diff unless its very early. Gearbox depends on if you want/have an auto or manual. trimatic is piss easy, 3 on the tree manual requires a bit of parts hunting. Box mount is the same. Engine mounts are easily available. You'll need the V8 radiator and driveshaft to suit your box 1 Quote Link to comment Share on other sites More sharing options...
gizzyguy Posted February 24, 2014 Author Share Posted February 24, 2014 gosh that's a long list,can see how it all adds up, lol,is awesome to see price n parts man thanks , Its a hx ute with a 202 in it.i have motor to go in but just unsure of the hard bits lol Quote Link to comment Share on other sites More sharing options...
danger Posted February 24, 2014 Share Posted February 24, 2014 Nothing hard about that then. Just find a gearbox, driveshaft, engine mounts and a radiator with pipes the other way round and your done. We do that shit in our sleep 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted February 24, 2014 Share Posted February 24, 2014 Mate. Bolts strait in mate. Have a look at oldholden.com mate. 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 24, 2014 Share Posted February 24, 2014 gosh that's a long list,can see how it all adds up, lol,is awesome to see price n parts man thanks , Its a hx ute with a 202 in it.i have motor to go in but just unsure of the hard bits lol Yeah that was with a fair bit of trademe searching and looking around for deals so it wasn't all "I need this so I'lll just buy it off the shelf" 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted February 24, 2014 Share Posted February 24, 2014 Considered sticking with the 202 and going to town on it? EG Turbo or a screw blower or something cool. the ozzys are getting 350-400hp naturally aspirated using some radical ford crank combo. 1 Quote Link to comment Share on other sites More sharing options...
gizzyguy Posted February 24, 2014 Author Share Posted February 24, 2014 have auto box..so it wont need diff?and tranz cross member bolts straight in? Quote Link to comment Share on other sites More sharing options...
danger Posted February 24, 2014 Share Posted February 24, 2014 Wont need diff, just different bellhousing. trans crossmember is the same. And 202's go pretty good but no young lady has every been scolded by her mother for being seen in a 6cyl holden ute 2 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 24, 2014 Share Posted February 24, 2014 Pretty sure the the 6 cylinder auto boxes don't bolt up to V8's 1 Quote Link to comment Share on other sites More sharing options...
gizzyguy Posted February 24, 2014 Author Share Posted February 24, 2014 . Quote Link to comment Share on other sites More sharing options...
gizzyguy Posted February 24, 2014 Author Share Posted February 24, 2014 has v8 tranz with motor..just didn't no if it bolts up to car with out modifying it Quote Link to comment Share on other sites More sharing options...
danger Posted February 24, 2014 Share Posted February 24, 2014 what's the motor out of? Quote Link to comment Share on other sites More sharing options...
gizzyguy Posted February 25, 2014 Author Share Posted February 25, 2014 not to sure ..will ask old owner .I got it with the 202 out and 308 and tranz on the back basically.. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 25, 2014 Share Posted February 25, 2014 Front sump bowl is commodore and rear is H series. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted February 25, 2014 Share Posted February 25, 2014 Just post up a picture of the engine/transmission combination so we can see what you've got there. Will most likely be a 308 and Trimatic combo. Is the ute currently automatic or manual? Quote Link to comment Share on other sites More sharing options...
dr.wylde Posted February 26, 2014 Share Posted February 26, 2014 ^^^^^ what these guys have said as long as you have the std driveshaft eg ( your one hasnt been chopped) you'll be sweet, I cant remember if HX uses a cable trottle setup if so you'll need a v8 throttle cable what side of the auto trans is the gear selector RH selectors are HQ- HZ specific LH are Commodores this may determine what gear selector you can use /tbar/column etc etc later LH LX torries use the same T bar auto shifters from memory for RH selector traumatics speaking of anyone got any leads on H series Ute driveshaft? ( sorry for thread hijack) Quote Link to comment Share on other sites More sharing options...
