cylinders Posted January 16, 2014 Share Posted January 16, 2014 Discuss the ghostly qualities of Casper, our new mini wags. No real plans as yet, some 13s or 14s in the 5.5 or 6jj region and a bit of drop and I'm hoping that will about do it. 1 Quote Link to comment Share on other sites More sharing options...
ryanfels Posted January 16, 2014 Share Posted January 16, 2014 These are 4x114 if they are the same as the California of the same model Quote Link to comment Share on other sites More sharing options...
HighLUX Posted January 16, 2014 Share Posted January 16, 2014 Should be leaves in the rear and coil front? Mikita lowering job 1 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted January 16, 2014 Share Posted January 16, 2014 It's got quite the face on it. Nice. 1 Quote Link to comment Share on other sites More sharing options...
cylinders Posted January 16, 2014 Author Share Posted January 16, 2014 Thanks guys, yes felsy they are 114 so should have a wide range of undesirable fwd offset stuff to choose from! Neil Rd Customs lowering kit? And the face, it perfectly matches the hilux, can't wait to sit them side by side! Quote Link to comment Share on other sites More sharing options...
agecage Posted January 18, 2014 Share Posted January 18, 2014 Put a e15et in it. Will give u way more power. Ive also got a e15et 5speed and a fuel injection manifold if u need. If u have any questions about e series motor dont heasatae to flick me a meassage ive been playin with the for ages. Quote Link to comment Share on other sites More sharing options...
Toucan Posted January 18, 2014 Share Posted January 18, 2014 I haven't seen this shape before, it rather appeals. Good score Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 21, 2014 Share Posted January 21, 2014 Just take a peak at all the hoses, not hard to figure out where the water goes. Probably a burst/loose hose or a busted outlet. Quote Link to comment Share on other sites More sharing options...
agecage Posted January 21, 2014 Share Posted January 21, 2014 All my e15 have been injected but there could be a coolant gallery running through the manifold. My car has a oil cooler that comes of the intake manifold. If your looking for help try going to www.n12turbo.com. they know evrything you need to know about e series engines. 1 Quote Link to comment Share on other sites More sharing options...
cylinders Posted January 21, 2014 Author Share Posted January 21, 2014 It definately appears to have a gallery in the manifold, inlet port on rh side outlet on lh side. Seems likely that frost plug or outlet area gasket has bust. Quote Link to comment Share on other sites More sharing options...
agecage Posted January 22, 2014 Share Posted January 22, 2014 I dnt think there ar any frost plugs on manifold, more likly a hose or manifold to head gasket. I think there's a water gallery on cam belt side, goin from head to manifold. Quote Link to comment Share on other sites More sharing options...
agecage Posted January 22, 2014 Share Posted January 22, 2014 If I was in your area I would come have a look at it for you but your a bit far away. 1 Quote Link to comment Share on other sites More sharing options...
cylinders Posted August 5, 2014 Author Share Posted August 5, 2014 If you seen the last update, give me your best onions on the way to lower this thing before I take out a telephone wire. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 5, 2014 Share Posted August 5, 2014 Lop a coil or 2 off the front with shortened shocks to keep shit captive if needed and im guessing the rear is leaf? If so how many per side? Quote Link to comment Share on other sites More sharing options...
Otodat Posted March 28 Share Posted March 28 Thread dredge. Anyone know what became of this wagon? I gather @cylindersmoved to Australia and hasn't been on here a while. Quote Link to comment Share on other sites More sharing options...
