ecu bulkhead / firewall connector
peteretep
I prefer to crimp over solder - if you use the right crimper that suits the pins in your connector you'll end up with tidy and reliable wiring.
http://www.msel.co.nz/epages/motorsportelectronics.sf/en_NZ/?ObjectPath=/Shops/motorsportelectronics/Categories/Connectors
If it were me id probably ditch the connector unless you plan on pulling the engine every other weekend/often. Like to keep things simple. That being said Ive got autosport connectors for my 7.
  • Replies 50
Doing what Tomstament said would work, but you would need a connector inside the car as not all the wires from teh ECU will go through the firewall, and would need a connector with just the wires going through the firewall etc
OR
a connector with all the wires NOT going through the firewall, so you can undo the main ECU plug and a little plug for tacho, power, acc etc that stays in the cabin and pull it out that way?
I just bought this
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=141158659256&ssPageName=ADME:L:OC:AU:3160
$65 delivered, I will let you guys know in a week or 2 what it actually looks like and its size. I'm not sure I understand how the wires are fitted into the pins
If it really comes down to it then I can do it tom misa spec though
and yeah, not all wires are going through the firewall
Edit: found some information, looks like an Amphenol connector (JT06RE-18-32PA) based on what I could get off the ebay images
http://www.amphenol-aerospace.com/connectorbasics - See "Contact And Termination Style"
http://www.amphenol-aerospace.com/pdf/catalogs/38999_III_Assembly_Instruct.pdf - Assembly Instructions (The recommended DMC crimp tool and turret needed to crimp the contacts is pricey)
With "mil spec" wiring commonly the entire loom is sealed with heatshrink (something like Raychem DR25) and the connectors are sealed with an adhesive lined heatshrink boot
Raychem DR25 is flexible and flame retardant, is resistant to most fuels (automotive and aviation), brake fluid, diesel fuel, hydraulic oil, lubricating oil and water.
For those interested in the subject have a look at http://www.rbracing-rsr.com/wiring_ecu.html
  • 3 months later...
