Lunacy Posted May 7, 2014 Share Posted May 7, 2014 Im using one of these in my car http://www.ebay.com/itm/22-Cavity-Weatherpack-Bulkhead-Connector-Pro-Kit-12-to-20-AWG-with-Removal-Tool-/231043368350?pt=Race_Car_Parts&hash=item35cb42059e&vxp=mtr Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 7, 2014 Share Posted May 7, 2014 Those weather packs are huge and yuck, I have one here and I'll never use it. Beat bet for 60 wires is run it through the firewall with a decent gromet and design it so the ecu plugs can come out the firewall hole. 2 Quote Link to comment Share on other sites More sharing options...
MRWEST Posted May 7, 2014 Share Posted May 7, 2014 think thats wqhat im going to have to do. Cut up my firewall pre paint. Quote Link to comment Share on other sites More sharing options...
thorburnville Posted May 9, 2014 Share Posted May 9, 2014 what about something like this: http://www.digikey.com/product-detail/en/206151-1/A1307-ND/15607Â Quote Link to comment Share on other sites More sharing options...
Rookie Posted May 9, 2014 Share Posted May 9, 2014 Bulk head connecters are lame. 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 9, 2014 Share Posted May 9, 2014 Yea lots of factory cars don't have them for a reason, I've had issues that ones that have them once they age. Quote Link to comment Share on other sites More sharing options...
Rookie Posted May 9, 2014 Share Posted May 9, 2014 There are a bunch of reasons that they are lame, and for the number of times that you actually take the engine out, they are best avoided. Quote Link to comment Share on other sites More sharing options...
Ned Posted May 9, 2014 Share Posted May 9, 2014 Plus that one isn't marked as water proof or anything Quote Link to comment Share on other sites More sharing options...
Testament Posted May 9, 2014 Share Posted May 9, 2014 So the solution is just run a magneto, mechanical injection and mechanical gauges on the cowl. 1 wire for the starter. done? 3 Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 9, 2014 Share Posted May 9, 2014 Crank handle start to save a 1 wire bulkhead? 2 Quote Link to comment Share on other sites More sharing options...
downtrail Posted May 10, 2014 Share Posted May 10, 2014 I agree unless its a highly tuned race car and you carry a spare motor to events that also is wired up for a quick swap then not really worth it. The less connections you can have in a cable the better as over time. Corrosion etc itll build up resistance in the plug leading to hard to find problems etc. Just goto pik a part lop off the loom of some car that runs a huge grommet and but that cut like a 2" hole or what ever size it needs and your off if you wire it with some thought in mind youll have no problems pulling the loom out again. This is all ive done with the race car number of times motor has been in and out over the years is like 4 number of times ive had to remove loom from car is 0 it just gets unplugged from coil packs injectors tps etc and flopped to the side takes around 3.5 mins to being fully electrically isolated to remove. 1 Quote Link to comment Share on other sites More sharing options...
