dave Posted December 28, 2013 Share Posted December 28, 2013 //oldschool.co.nz/index.php?/topic/41714-rb-drifters-1980-ex-lancer/ fuckin burn the rice hua Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted December 28, 2013 Share Posted December 28, 2013 Looks tough in some of the pics Quote Link to comment Share on other sites More sharing options...
rb drifter Posted December 29, 2013 Share Posted December 29, 2013 comment away, any help with advice on this would be much appreciated. first dohc 4g63 build for me. also if anyone wants little interior bits I do have some that wont be needed. just hit me up. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted December 29, 2013 Share Posted December 29, 2013 have you considered doing fitting late model evo head (like my mazda build), I reckon it's pretty trick and is handy to position the turbo on the passengers side.. Quote Link to comment Share on other sites More sharing options...
rb drifter Posted December 30, 2013 Share Posted December 30, 2013 I did wonder if that would work, I had issues with my starion sohc turbo setup it keept melting the brake and cluch reservoir and was something I don't want to happen on this. Quote Link to comment Share on other sites More sharing options...
rb drifter Posted December 30, 2013 Share Posted December 30, 2013 upto dave already got a thread hua boi Quote Link to comment Share on other sites More sharing options...
rb drifter Posted December 30, 2013 Share Posted December 30, 2013 can which ever mod changed my discuss thread change this title its a bit stupid, dave didn't take his pills Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 30, 2013 Share Posted December 30, 2013 Yeah, I'll sort it. I merged them but because his was older yours went under his heading, I chuckled and went back to work. Quote Link to comment Share on other sites More sharing options...
rb drifter Posted December 30, 2013 Share Posted December 30, 2013 cheers man, Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted January 5, 2014 Share Posted January 5, 2014 Double check the diameter of the 2 struts bro. Starion might be slightly bigger so the sleeve on the other struts may not fit. RE: Lancer problems - Story of my life Quote Link to comment Share on other sites More sharing options...
rb drifter Posted January 5, 2014 Share Posted January 5, 2014 yeah I measured them just after I posted that and realised haha ex was about 51mm od and starion 54mm od. would anyone happen to know if the cluch off a g32b will be the same as 4g63 sohc? need to fix cluch in my green lancer and im on a budget till pay day haha Quote Link to comment Share on other sites More sharing options...
vegie Posted January 5, 2014 Share Posted January 5, 2014 re coilover sleeves. I used some like that on my first set of coilovers too. I found that the real fine pitch threads like those ones, shit their pants really quick. when you go to adjust them the threads are all damaged and galled up some stones getting between them and the spring. I replaced mine with a coarse thread type off some teins, and problem gone. might save you some hassles later on... Quote Link to comment Share on other sites More sharing options...
rb drifter Posted January 5, 2014 Share Posted January 5, 2014 cheers man, yeah I will have to get new sleeves now due to them being different size. but if coilovers are gunna be to hassle ill just rock shortened as fuck struts. cause once its bumped I wont be making it high again. 1 Quote Link to comment Share on other sites More sharing options...
ProZac Posted January 5, 2014 Share Posted January 5, 2014 Crank Signals = Kiggly Racing 6 bolt trigger setup. Cam Signals = some year RVR turbo/94-95 2g eclispe turbo front cam trigger setup Then all your triggering done from the front of the motor = no CAS on the back of the head needed = no bashing/welding firewall. Tis what I'm doing, but with my own version of the Kiggly Racing bits, as they're hellishly expensive for what they are. Requires removal of your balance shafts, but you were going to do that anyway, right? That's if you want to run a factory ECU of some sort. EVO 5/6 ecu's can be had cheap and are very tunable in situation. Even better are the EVO 7 and 8 ecu's, but are usually a little more spendy. An EVO 1-3 ecu, or some of the VR4 ecu's are also dooable, but require socketing and emulators. They can, however, be tuned in real time, which is nice... But not overly important if you were going to have a bash at it yourself. That triggering setup would actually be sweet even if you went the MS/Link ECU route, as it'd let you do everything sequential styles. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted January 5, 2014 Share Posted January 5, 2014 Nah, 4G32 and 4G63 run different clutches Quote Link to comment Share on other sites More sharing options...
rb drifter Posted January 6, 2014 Share Posted January 6, 2014 cheers zac yeah balance shafts getting removed. my cousin has wired a gsr motor to an ex before so he can surely do this one but as to the ecu standard evo 5/6 will probly do for now but my cousin is saying I should get link but itll be a while before I worry about looms/ecus as this will probly take me most of the year if not longer to build. shit sticks! anyone got a 4g63 sohc cluch? or will vr4 work? does that mean that g32b gearbox are different too? Quote Link to comment Share on other sites More sharing options...
rb drifter Posted January 6, 2014 Share Posted January 6, 2014 ive never had anything less than a 2litre so excuse my ametureness Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted January 6, 2014 Share Posted January 6, 2014 Yep, 4G32 had the KM119 gearbox whereas the 4G63 uses the KM132 The KM119 is slightly smaller And input shaft is smaller. Quote Link to comment Share on other sites More sharing options...
