oil warning light
d.p.n.s
They need different senders. Light is a on/off switch. Gauge is a variable sender.
Someone smarter than might prove me wrong tho.
No you're pretty smart.  Light is a switch and gauge is a variable sender.  You could do some electronics that say when variable sender has a certain signal level fire up a warning light.  Some flash gauges can do the warning stuff in the gauge I think.
Brass tee piece, switch sender and gauge sender.
Edit: Beaten!
