d.p.n.s Posted October 13, 2013 Share Posted October 13, 2013 i have a oil pressure gauge and i also want to run a oil warning light and im just wondering can i run then of the same sender or do i need 2? cheers all Quote Link to comment Share on other sites More sharing options...
AllTorque Posted October 13, 2013 Share Posted October 13, 2013 They need different senders. Light is a on/off switch. Gauge is a variable sender. Someone smarter than might prove me wrong tho. 1 Quote Link to comment Share on other sites More sharing options...
sheepers Posted October 13, 2013 Share Posted October 13, 2013 I just ran aT off the pressure outlet on the block and put one sender unit in each end. I'm sure you can do it with one sender and heaps of Fucking around but why use a sledge hammer to crack a Walnut ay? 1 Quote Link to comment Share on other sites More sharing options...
Ogre Posted October 13, 2013 Share Posted October 13, 2013 T joint is definitely the way to go. Quote Link to comment Share on other sites More sharing options...
vivaspeed Posted October 13, 2013 Share Posted October 13, 2013 They need different senders. Light is a on/off switch. Gauge is a variable sender. Someone smarter than might prove me wrong tho. No you're pretty smart. Light is a switch and gauge is a variable sender. You could do some electronics that say when variable sender has a certain signal level fire up a warning light. Some flash gauges can do the warning stuff in the gauge I think. Brass tee piece, switch sender and gauge sender. Edit: Beaten! Quote Link to comment Share on other sites More sharing options...
Valiant Posted October 13, 2013 Share Posted October 13, 2013 T joint or VDO (from memory) make a sender that has a resistor for a gauge and a switch in it. Quote Link to comment Share on other sites More sharing options...
mattscort Posted October 13, 2013 Share Posted October 13, 2013 They need different senders. Light is a on/off switch. Gauge is a variable sender. Someone smarter than might prove me wrong tho. nailed it switch vs sender edit beaten like a leper on leper beating day Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 14, 2013 Author Share Posted October 14, 2013 thanks gents Quote Link to comment Share on other sites More sharing options...
