ex lancer wat! Posted July 9, 2013 Share Posted July 9, 2013 i am installing a willwood pulltype slave cylinder into my car. it recommends a 3/4 master cylinder and i already have a 5/8 master installed. this means i will be underpowering the slave cylinder. does anyone know what the affects of underpowering the slave will be, will the pedal be softer and will the piston get less stroke? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 9, 2013 Share Posted July 9, 2013 Pedal will be softer and you will get less stroke (most probably not enough stroke for the clutch to disengage) Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted July 9, 2013 Share Posted July 9, 2013 You will have more pedal stroke but less at the slave end. If that's what you meant kk. Hah Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 9, 2013 Share Posted July 9, 2013 It will be harder to push the clutch pedal, and you will need to push it further to disengage the clutch. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 9, 2013 Share Posted July 9, 2013 LOL - you sausage head Dave  What I mean is you will have identical pedal stroke as the pedal will go to the floor whether you have 5/8th or 1 1/16... But yes I did mean less at the slave end - but that's made kinda obvious by the fact that the pedal stroke does not change so it must be the slave end.  But other Dave is right - the pedal will be harder. Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 9, 2013 Share Posted July 9, 2013 Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 9, 2013 Share Posted July 9, 2013 I'mma talking about the range at which it engages/disengages over, so it might be a good thing is you have a really grabby clutch etc. Quote Link to comment Share on other sites More sharing options...
ex lancer wat! Posted July 9, 2013 Author Share Posted July 9, 2013 yes its a 4 puk with heavy duty pressure plate. would anyone know the measurement of how far the release bearing needs to press into the pressure plate for the clutch to disinguage Quote Link to comment Share on other sites More sharing options...
kpr Posted July 10, 2013 Share Posted July 10, 2013 the toyota ones i've had done at autoclutch have had "6mm release" written on them.  would likely be something similar  could put it in a press and try it. if its out of the car Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted July 10, 2013 Share Posted July 10, 2013 K-trips is the most correct reply here. Actual clutch bearing movement will change with fork ratio so just try it with what master you have and if not enough go to a bigger master. Quote Link to comment Share on other sites More sharing options...
cubastreet Posted July 11, 2013 Share Posted July 11, 2013 kk was right first time - pedal will be softer with less travel at the clutch end. Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 11, 2013 Share Posted July 11, 2013 . Quote Link to comment Share on other sites More sharing options...
