ex lancer wat!
Everything posted by ex lancer wat!
Is a Manuel and automatic starter motor interchangeable on a 4k ke70.
rear diff housing arm bushes for ex lancer
ex lancer wat! replied to ex lancer wat!'s topic in Tech Talk
think autoline is my best bet. i used to work at repco and theres nothing so i doubt bnt will have and definitely not supercheap -
Hey team. Wanting to know if anyone on here has replaced the bushes in a rear end for a ex lancer as I cant seem to find aftermarket ones. If you have any ideas or part numbers please pm me thanks andy
hi my ke70 lowbeams are not working. the high beams still work fine. the fuses are fine and bulbs are fine. what else could it be. has anyone else struck this problem. thanks andy
yes its a 4 puk with heavy duty pressure plate. would anyone know the measurement of how far the release bearing needs to press into the pressure plate for the clutch to disinguage
i am installing a willwood pulltype slave cylinder into my car. it recommends a 3/4 master cylinder and i already have a 5/8 master installed. this means i will be underpowering the slave cylinder. does anyone know what the affects of underpowering the slave will be, will the pedal be softer and will the piston get less stroke?
i have a ex lancer and it is low but will be going lower. it will be running approx 350hp ATW. im deciding if i run a two piece dshaft or single piece. what are the advantages and disadvantages bearing in mind the low height of the car and the power it will be running
be4vers 4G63 EX Lancer 1981 Discussion
ex lancer wat! replied to Sparkle's topic in Project Discussion
Hey man they look like factory turbo rear brake pads correct? Iv got the trw part number if u like. I used to work at repco so I looked hard for this part number in old books etc I'll get it again tomorrow as I know there are still some available in nz -
Is there a trick to pushing the piston back? Won't really retract for me is there a special tool as I read with some caliapers the piston turns on a thread so you need a special tool. Is this the case for me or the cars just old and full of head aches
That would be pads are fuel? I got pads sorted now need rotors
i know people have had trouble finding the pads to suite aswell but iv tracked the trw part numbers for those down so sing out if you would like them posted on here
wanting to replace my brake rotors in my 1800 gsr lancer 1982 but im having trouble finding part numbers can anyone help. (wanting to replace front and rear) somebody must know
Sweet all is in and looks pretty cool
So I'm guessing when you say 1600 sigma ones are same as ex arms that this means they will look identical to each other and not be the bolt in type
Got some lower arms out of a sigma the bull joint is a bolt on is this the right type for ex. Want camber!
Also radius rods line up?
So sway bar link lines up? Are the arms much longer?
Has anyone fitted sigma arms to a ex. Did ant mods need to be made and how much camber was gained?
Yeah I need someone to supply me with new ring gear chch if pos
I'm needing the ring gear on my fly wheel changed. I'm in chch where and who would be the place to go to?
seats and carpet came up really well. i do think black seatbelts will make it look even better! -
My factory turbo radiotor (broke last week) was slightly bigger that a 1200 and a 1600 I thought but I'll go do some mesurements -
pretty awesome to see all these factory turbo lancers comeing out of the wood work! will look the part with a good clean! not a bad score -
Will be running the rebuilt turbo 10 bolt LSD.
