Beaver's WunTwennyWhy Coupe
kicker
  • Replies 701
That looks dayum fine son..
I'm very hesitant to say to grind down your callipers or mounts - it may need 10mm clearance now but when you put new pads in then it will be even more as the calliper moves across when you put new/wider pads in.. (your current pads look about 1/3 to 1/2 worn)
I would roll the guards and chuck 15mm spacers at it..
That is a fair bit of meat to chop off the caliper.
Is 10-15mm going to hurt you thaaat much? It looks to have a bit of clearance to turn still, loaded up around a corner it may touch but just lip the guards and the tyre rubbing on a flat surface will do fuck all.
How about a 5mm spacer and then 5mm off the caliper?
