Beaver Posted October 29, 2012 Share Posted October 29, 2012 oh man, that means so much to me..... Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 29, 2012 Share Posted October 29, 2012 be quiet. who said anything about smaller tyres. nwo go away with all your negativity. What negativity? Why I oughta... I'LL GIVE YOU NEGATIVITY, SHITTY CAR FAGGOT! *throws toys* Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 5, 2012 Share Posted November 5, 2012 That looks dayum fine son.. I'm very hesitant to say to grind down your callipers or mounts - it may need 10mm clearance now but when you put new pads in then it will be even more as the calliper moves across when you put new/wider pads in.. (your current pads look about 1/3 to 1/2 worn) I would roll the guards and chuck 15mm spacers at it.. Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 5, 2012 Share Posted November 5, 2012 hmm yeh thats good thinking about the pads. I have a brand new set so could compare and see....but I think you are right....god dammit. 15mm will give gay poke and look silly Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 5, 2012 Share Posted November 5, 2012 Are you guessing 10mm or have you done some calcs? Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 5, 2012 Share Posted November 5, 2012 I have done calcs/spaced the wheels out with washers and 3 washers/10mm worked. I hve a brand new set of pads so will looks how much bigger they are and that might change the picture quite a bit.... Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 5, 2012 Share Posted November 5, 2012 Ah OK - where is it touching on the wheel? Is there room to take some out of the wheel? Perhaps find out if there is a smaller calliper bracket - the datsun guys will know for sure.. Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 5, 2012 Share Posted November 5, 2012 its fouling no the spokes, just outside the flat mounting face. 10mm is a decent chunk to take from there....good thinking re:caliper bracket, will have an ask Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 5, 2012 Share Posted November 5, 2012 Damn - Smaller calliper mount or spacers with rolled guards are your only options son. Grinding off that much could be a bad move. Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 5, 2012 Share Posted November 5, 2012 hmmm, there are some brakes on trademe which are apparently 120y and the caliper mount thingy is slightly different so might be worth a shot. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 5, 2012 Share Posted November 5, 2012 These ones? vs Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 5, 2012 Share Posted November 5, 2012 Yup dem ones Quote Link to comment Share on other sites More sharing options...
Goat Posted November 6, 2012 Share Posted November 6, 2012 You could just buy daves wheels and roll them super slammed... 1 Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted November 6, 2012 Share Posted November 6, 2012 That is a fair bit of meat to chop off the caliper. Is 10-15mm going to hurt you thaaat much? It looks to have a bit of clearance to turn still, loaded up around a corner it may touch but just lip the guards and the tyre rubbing on a flat surface will do fuck all. How about a 5mm spacer and then 5mm off the caliper? Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 6, 2012 Share Posted November 6, 2012 chop chopped last night, doesnt look like much in the scheme of things. will see how it goes. if it looks to dodge will just grab another set and venture down the spacer route. Quote Link to comment Share on other sites More sharing options...
durty Posted November 9, 2012 Share Posted November 9, 2012 looking schmick as Brakes haven't fallen out? Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 9, 2012 Share Posted November 9, 2012 haha nah so far so good. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted November 9, 2012 Share Posted November 9, 2012 Spotted this driving by the stadium this moaning. Looked so lush. Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 9, 2012 Share Posted November 9, 2012 yeh your mum was moaning as well. did you toot? I remember a rouge toot Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted November 9, 2012 Share Posted November 9, 2012 Yeah I tooted and threw erratic gang signs/handi hands. Quote Link to comment Share on other sites More sharing options...
