gtluce Posted July 22, 2014 Share Posted July 22, 2014 this is a picture of how my project Is going im using it as my daily at the moment. still need to do a few more things to it and needs to go a lot lower 2 Quote Link to comment Share on other sites More sharing options...
gtluce Posted July 22, 2014 Share Posted July 22, 2014 3 Quote Link to comment Share on other sites More sharing options...
mutiny Posted July 23, 2014 Share Posted July 23, 2014 haha thats my old number plate 1 Quote Link to comment Share on other sites More sharing options...
gtluce Posted July 25, 2014 Share Posted July 25, 2014 How long ago did you have them plates Quote Link to comment Share on other sites More sharing options...
mutiny Posted July 25, 2014 Share Posted July 25, 2014 while ago now probably 6 or 7 years, i brought em new, sold em with my old luce to a friend Quote Link to comment Share on other sites More sharing options...
gtluce Posted July 27, 2014 Share Posted July 27, 2014 Funny thing I think I own the luce they were on to. 1985 gun grey and silver two tone paint was on silver rs5s Quote Link to comment Share on other sites More sharing options...
R100 Posted July 27, 2014 Author Share Posted July 27, 2014 Bro keep on topic. This thread is about my wagon ill never finish. Stay tuned ill try post up some more pics of some mags i want to put on it or a head deck ill put in it then later on sell. But in all honesty i do need to make some progress on it as its stick on my hoist. 2 Quote Link to comment Share on other sites More sharing options...
h4nd Posted July 28, 2014 Share Posted July 28, 2014 Gonna have some awesome flares for those guards. Got a plan / parts, or gonna fab em up? Quote Link to comment Share on other sites More sharing options...
gtluce Posted July 29, 2014 Share Posted July 29, 2014 Since Ive built my terrano. Alot of people have been interested in building one for themselves. I wonder how many more will come out of the woodwork. Ive put a couple of photos of mind up on the local chch pages and ive had mainly good feed back about it Quote Link to comment Share on other sites More sharing options...
R100 Posted July 29, 2014 Author Share Posted July 29, 2014 Theres not to many of these conversions out there, that i know of anyway. Quote Link to comment Share on other sites More sharing options...
R100 Posted November 4, 2015 Author Share Posted November 4, 2015 Have done a bit more on this project but not much. I lifted the front leaf brackets 25mm and remade the area going over the diff head to be a little shallower to allow for the head not hitting it. Fuel tank sits to high and needs approx 35mm cut out of it to make it clear the terrano body (tank is from a ute) I have sliced the tank in half and will weld is back together, will also need to shorten up the fuel gauge sender and intank pump assembly to suit. BEFORE AFTER Quote Link to comment Share on other sites More sharing options...
R100 Posted November 4, 2015 Author Share Posted November 4, 2015 2 Quote Link to comment Share on other sites More sharing options...
R100 Posted May 16, 2016 Author Share Posted May 16, 2016 Bit of an update. I decided on a TD42 Turbo for maximum torks. Engines quite long so one of the cylinders bobs up and down under the dash. Will chuck some better pics up next week or something. 9 Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 16, 2016 Share Posted May 16, 2016 What's the length of a TD42 anyway? Are they significantly longer than say, an RD28? 2 Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted May 16, 2016 Share Posted May 16, 2016 piston diameter is 96mm according to interwebs there ky. They are pretty massive, the waterpump and accessories add a bit of length too. 1 Quote Link to comment Share on other sites More sharing options...
R100 Posted May 16, 2016 Author Share Posted May 16, 2016 800mm front front pulley/water pump to where bellhousing bolts up. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted May 16, 2016 Share Posted May 16, 2016 what gearsack will you use? i approve of this, i had dirty thoughts about putting a td42 in the valiant ute i had 2 Quote Link to comment Share on other sites More sharing options...
R100 Posted May 17, 2016 Author Share Posted May 17, 2016 TD42's in everything i say. As much as i would love a manual i felt as though i really needed something decent behind the TD42 and no W series or Nissan "big box" would cut it. The safari/patrol 5 speed FS5R50A boxes are more or less a truck gearbox. Not only are they friggin huge, they are very hard to find in RWD format. Even then they are a remote shifted box as used on a Civilian bus. The standard Safari, Patrol, Civilian auto trans is a RE4R03A with a 4WD transfer box bolted to it. Im using a RE4R03A from a 300ZX (VG30DETT) bolted to a standard TD42 bellhousing. Its semi electronic so i will need to do some electronic trickery to make it work correctly. Should tow pretty mean once completed. 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted May 17, 2016 Share Posted May 17, 2016 Hey man. You can make that trans operate manually without the ecu quite easily. Im a real fan of that box after fiddling with my safari one. The same box is behind vh45 motors in the leopard (I think) and it has more clutch plates than the safari version and maybe yours too -maybe worth checking. There are differences in the input shaft too - it's either longer or shorter for the diesels compared to that on the VH version so you may want to swap em over. If you REALLY Wanted to be flash you could have someone create a simple circuit to enable the use of paddle shifters. Quote Link to comment Share on other sites More sharing options...
R100 Posted May 17, 2016 Author Share Posted May 17, 2016 Hey man. You can make that trans operate manually without the ecu quite easily. Im a real fan of that box after fiddling with my safari one. The same box is behind vh45 motors in the leopard (I think) and it has more clutch plates than the safari version and maybe yours too -maybe worth checking. There are differences in the input shaft too - it's either longer or shorter for the diesels compared to that on the VH version so you may want to swap em over. If you REALLY Wanted to be flash you could have someone create a simple circuit to enable the use of paddle shifters. From my understanding if i get it running with no electronics i should have second and third only ? If thats the case 1st can be on a button and so can 4th (overdrive) as there's already a button on the factory terrano shifter for this. Always hard to find any good information when your building random weird shit. Quote Link to comment Share on other sites More sharing options...
