Ignition only systems for injected engines running carbs
R100
Whats the simplest ignition only system that can be used for an injected engine that now runs carbs. Is there a simple wasted spark system or similar avalible off the shelf ?
Wanting to run a carburettor on a 1UZ or a distributorless engine such as an RB20
Didn't Slacker Cam run a Link on his AE86 4AGE with carbs just to run the ignition?
Most probably easier solutions - MSD may have one - I know they have exactly what you are asking for for an LS1 but not sure on 1UZ.
The one I mean is this http://www.msdignition.com/product.aspx ... terms=6012
More options here http://www.msdignition.com/info.aspx?taxid=4&taxid2=108
Ford EDIS setups still need an ECU (ignition only or otherwise) to run, this is what I am intending to do with my 5K. Have the EDIS bits and pieces + a toothed wheel, just need to settle on the ECU. Leaning towards a Link G4 Lightning, which is an ignition only ECU that is used frequently speedway situations so I am lead to believe. Has an inbuild MAP sensor too which is nice/probably not much use to me with bike carbs.
My primary reasons for choosing the Link are readily available backup, elegance and it's a well proven product. Not the most cost effective however.
Link Have released a ignition only computer but its probably a bit of overkill for what you want
http://www.linkecu.com/products/engine- ... _lightning
