Valiant Posted February 26, 2012 Share Posted February 26, 2012 I'm pretty sure an Escort box won't fit your Cortina mount, you'll need a custom mount and technicaly a cert too. Clutch wise it's 50/50. Your Cortina was designed for hydraulic though so swapping bits off another one is easier/ Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 26, 2012 Share Posted February 26, 2012 just keep it simple man, get a 4 speed from a cortina that will bolt up to your motor and just put up with have the gearstick close to the bench, or bend the gearstick forward. Quote Link to comment Share on other sites More sharing options...
Horse25 Posted February 26, 2012 Share Posted February 26, 2012 If felixx doesnt want it you can have it, no use to me, its either an early cortina or angrybox, has hydraulic clutch Quote Link to comment Share on other sites More sharing options...
felixx Posted February 26, 2012 Share Posted February 26, 2012 Horse, i think Burrowsj needs it more than me. Quote Link to comment Share on other sites More sharing options...
Valiant Posted February 26, 2012 Share Posted February 26, 2012 Burrowsj wreck that column change car. Come on, are you ever going to fix it? How much do you want your other one to go? Do it. Quote Link to comment Share on other sites More sharing options...
felixx Posted February 26, 2012 Share Posted February 26, 2012 and Pete has spoken. He is the voice of logic. And I might have a buyer for the auto,perhaps.. Quote Link to comment Share on other sites More sharing options...
burrowssj Posted February 26, 2012 Author Share Posted February 26, 2012 I just happen to have a fully driveable manual column shift dereg cortina in my driveway. But its not mine ]and its to good to part out. Would only take some rust repairs to get it close to road legal.Unfortunately I have to piece things together at this stage Its not my car and my brother wont even give me a cheaper deal on it unfortunately. If I could I would have done it already. He wants 1500 for the car. probably need anther 1500 work to get it on the road and its in no way tidy needs twice the work mine does And like I said, its to good to part. its got about 4 rust holes. needs new carpets an a repair on front seat. Its got maybe 3 dents that are notable and need fixing, the grill is damaged, the Brakes are sloppy and suspension is sloppy to... Wouldn't take a hell of a lot to get it on the road and considering how many are left it would be sad to scrap it for a gearbox. That and once I take the gearbox out theres not much left to scrap except metal Plus im a hoarder and I wouldn't let anyone near it Quote Link to comment Share on other sites More sharing options...
Valiant Posted February 26, 2012 Share Posted February 26, 2012 Try i5oogt on here. He has a couple of Cortinas and may be able to help. Quote Link to comment Share on other sites More sharing options...
governorsam Posted February 26, 2012 Share Posted February 26, 2012 this guy has an auto from an escort if that helps.. //oldschool.co.nz/phpbb/viewtopic.php?f=17&t=31963&p=792804#p792804 Quote Link to comment Share on other sites More sharing options...
burrowssj Posted February 29, 2012 Author Share Posted February 29, 2012 I got box thanks to horse teeth on reverse are worn.How much wear is to much? the rest of the box looks good. Is there a way to test the bearings? Does anyone know what flywheel I need? its a 1500 cortina box onto a 1600 block. And will I need the 1500 starter motor? 20 questions I know Quote Link to comment Share on other sites More sharing options...
- i5oogt - Posted February 29, 2012 Share Posted February 29, 2012 i dont think theres much difference between the 1500/1600 flywheel, I will check my 1600 auto and see what starter it has, im 99% sure they are the same between the auto and the manual. i have a pedal box, possibly the master and slave cylinders too also felixx i have one of those floor change boxes sitting in the shed if you need one Quote Link to comment Share on other sites More sharing options...
Unclejake Posted February 29, 2012 Share Posted February 29, 2012 The 120E 1500cc flywheel has only four crank bolts. The 1600cc is six bolt. There was an interim engine that is sometimes called a 1500cc with a six bolt crank (and lip seal instead of rope seal). It was called something like a 2136 (I can't remember) Most everything else is the same. Quote Link to comment Share on other sites More sharing options...
burrowssj Posted March 1, 2012 Author Share Posted March 1, 2012 box was filthy, so got the petrol out an gave it a good clean down this arvo. underneath a good 3mm of grime I found and original "ford 109e" sticker the box has 118e on the side as well as t50 any ideas one what those mean? Quote Link to comment Share on other sites More sharing options...
burrowssj Posted March 18, 2012 Author Share Posted March 18, 2012 So took old bellhousing out today to find that the box I got from horse won't fit >.< the mounting points are different. back to square one. Also does anyone know how to split torque convert from engine? I got the 4bolts holding it together off but it seems to just spin freely without coming off? My manual had no mention of how to remove it so Wondering what ive missed Quote Link to comment Share on other sites More sharing options...
