shadow69 Posted February 25, 2012 Share Posted February 25, 2012 Hey all new to this site, So have read through other post about brakes. I'm having problems bleeding brakes, I have tried everything, i've bleed clockwise anti clockwise, diagonally, had someone pumping the pedel while i bleed them, raised the rear of the car, clamped hoses. I have all new hoses, master cylinder and slave cylinders. Please what am I missing is driving me mad lol Shadow Quote Link to comment Share on other sites More sharing options...
felixx Posted February 25, 2012 Share Posted February 25, 2012 where are you shadow? I too own a 105e and had all manner of issues. 1) new hoses, check there is no weeping from joints, I had a flare nut fail. 2) New master cylinders, I had one of them that I suspect leaked from the start 3) Wheel cylinders - the bleed valve on the front is at the bottom, remove the hubs and bleed them upside down 4) use heaps of brakefluid to get rid of any bubbles Quote Link to comment Share on other sites More sharing options...
Llama Posted February 25, 2012 Share Posted February 25, 2012 Make sure you pump the brakes slllloooooowwwww. Else the turbulence mixes up the air bubbles already in the system and then they reform after settled for a while. If you've got metal lines, check that none of those have been crushed/dented as they act as check valves if you do. What happens after you try bleeding them? Still having a spongy pedal? Are you keeping the master topped up as you go? Quote Link to comment Share on other sites More sharing options...
shadow69 Posted February 26, 2012 Author Share Posted February 26, 2012 Hey felix and llama, Im in auckland, As far as I can see everything ok no dents or anything, I will go through and re check all joints. Raaaa lol Shadow Quote Link to comment Share on other sites More sharing options...
anglia4 Posted February 27, 2012 Share Posted February 27, 2012 Is the pedal spongy or do they just have no stopping power? If its the latter then you might need to dress the linings Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 27, 2012 Share Posted February 27, 2012 Have you adjusted the brakes all round? Quote Link to comment Share on other sites More sharing options...
shadow69 Posted February 27, 2012 Author Share Posted February 27, 2012 If i pump it hard there is a bit of tension but when I push down again it goes to the floor, I was thinking if adjusting them would make a difference so will try that. Also the car isnt running currently was thinking about getting her running would that make a difference? maybe help ear bubbles move through? Sorry what do you mean by dress the linings anglia4? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 27, 2012 Share Posted February 27, 2012 Definitely check the linings are all OK and adjust the brakes first - I assume you have bench bled the master cylinder? If not then do that, then move onto bleeding the wheel from the furtherest away from the master cylinder and move to the closest. Keep the fluid full as much as possible and give it nice even presses of the pedal like you are squeezing the accelerator down - around 1 stroke up or down every 1 or 2 seconds is best - otherwise you can airate the fluid if you pump it too hard and fast. If these things give no result - then check that the master-cylinder to pedal pushrod length is not too long and preventing the master cylinder piston returning home each pedal stroke. You normally adjust this with the threaded adjuster between the pedal and master - if it does not have a threaded adjuster then you will need to grind it down with a bench grinder - thus this is the last resort - cos obviously you can't easily add more length back on once you have taken it off.. Hope this helps. Quote Link to comment Share on other sites More sharing options...
shadow69 Posted February 27, 2012 Author Share Posted February 27, 2012 cool thanks heaps will try all those things and get back to ya's appreciate the help shadow Quote Link to comment Share on other sites More sharing options...
felixx Posted February 27, 2012 Share Posted February 27, 2012 In anglias post 64 there is no pushrod adjustment. Adjust up your brakes first, this could be 1/2 your problem, also if the wheel cylinders have extended too far, they may have begun to leak. Are you losing fluid? If so, where is it going? If you are not losing fluid, then there is air. Also running the engine will make no difference sorry Quote Link to comment Share on other sites More sharing options...
felixx Posted February 27, 2012 Share Posted February 27, 2012 also the manual talks about a snail cam adjuster and a wedge adjuster on the rear brakes. Mine has no snail cam. I think I have the back brakes in mine sorted although the handbrake does fek all Quote Link to comment Share on other sites More sharing options...
shadow69 Posted February 28, 2012 Author Share Posted February 28, 2012 Hey, yeah no leaks thats why I thought it was air Quote Link to comment Share on other sites More sharing options...
shadow69 Posted February 28, 2012 Author Share Posted February 28, 2012 Hey all, does anyone have a picture of how front brakes should be set up I think the cylinders and shoes are set round the wrong way but i'm just not sure Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 28, 2012 Share Posted February 28, 2012 Take a pic of yours and I'll give you a rundown Quote Link to comment Share on other sites More sharing options...
shadow69 Posted February 28, 2012 Author Share Posted February 28, 2012 Hey, have a problem I cant attach a photo Quote Link to comment Share on other sites More sharing options...
Toucan Posted February 28, 2012 Share Posted February 28, 2012 viewtopic.php?f=11&t=24810 Quote Link to comment Share on other sites More sharing options...
shadow69 Posted February 29, 2012 Author Share Posted February 29, 2012 Great thanks for that toucan. Here is the image: Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted February 29, 2012 Share Posted February 29, 2012 looks pretty good to me Quote Link to comment Share on other sites More sharing options...
Raizer Posted February 29, 2012 Share Posted February 29, 2012 Might be just about time for some new shoes though Quote Link to comment Share on other sites More sharing options...
shadow69 Posted February 29, 2012 Author Share Posted February 29, 2012 Yeah noticed that to dam it lol.. that wont effect the bleeding thought will it? Quote Link to comment Share on other sites More sharing options...
