escort engine mounts
eskie77
hey been doing a bit of work on my escort over the weekend and noticed the engine sump sits on the steering rack.The engine mounts are spaced out with steel but still not enough to clear the sump.Can you get longer engine mounts for to clear the sump and are they 1600 ones or 1300 ones or what lol.The engine im running is a 1600
any help greatly appreciated :)
Hey when I did a 1600 conversion to my mk1 I had this problem after much research I found that I did have the correct two engine mounts and both on the same side, my issue was my sump. Some of th cortinas have the bowl on the oppisite side to the escort but theres one that has the same side but its a larger bowl and sits on the steering rack.
I ended up basing out a 1300 sump to work.
