OSM Garage Posted August 14, 2011 Share Posted August 14, 2011 Calling all Nissan techies! I have a Nissan Prairie with a SR20 that wont start. Apparently (car belongs to a female) the car ran fine when they parked it in the garage. It sat for a couple of days and when they tried to start it up to day it started, then conked out, and wouldnt start again. Just had a look at it and when the engine is turned over it almost sounds like there is no compression. There is also a slight fuel smell. When cranking the cat light and airbag light comes on. Engine light is on as well. Im gonna tow the car to my place tomorrow and have a better look at it but in the meantime does anyone know what may be the cause of this fault? (from the vague description) Churbro Quote Link to comment Share on other sites More sharing options...
revxs Posted August 14, 2011 Share Posted August 14, 2011 Sorta sounds same as what happened to my sr20,Would fire then seem to flood itself and just sit there winding over sounding like it had no compression,Used to leave it and come right,one day wouldnt start at all,Turned out the be the fuel pump Quote Link to comment Share on other sites More sharing options...
fuel Posted August 14, 2011 Share Posted August 14, 2011 SR20s often have an issue with the hydraulic lifters pumping up too much and leaving the valves partially open, therefore giving you little to no compression. Often it is because of the viscosity of the oil used - I would do an oil change with 10W40 or 15W40, unplug the fuel injectors or just remove the fuse to the ECU and then keep winding it over until it starts to get more compression, then plug injectors/ecu fuse back in and see if it fires. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted August 14, 2011 Share Posted August 14, 2011 ^what he said, they hate old oil/crud/sludge speshly when its cold outside might be worth chucking some cleaner in there too to chew the insides of the lifters clear Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted August 14, 2011 Author Share Posted August 14, 2011 Good tips. Cheers guys. Makes sense if it is indeed the lifters. No compression = No fire. That may also explain the gassy smell huh? might be worth chucking some cleaner in there too to chew the insides of the lifters clear What cleaner would be suitable? Quote Link to comment Share on other sites More sharing options...
toyworld Posted August 14, 2011 Share Posted August 14, 2011 they flood easy too. put ya foot flat on the pedal and winde it over for ages, hook up some jumper leads if you have too. i wouldnt bother pulling egi fuse or anything. plugs will be wet, shitty old s.plugs dont help either, you can check one if you want. next oil change use promar mbl8 as per instructions Quote Link to comment Share on other sites More sharing options...
R3spct Posted August 14, 2011 Share Posted August 14, 2011 I'd pull the Fuel Pump relay under the bonnet, and crank it with foot flat, maybe remove plugs and spray with brake clean, crank over with plugs out, watch out for sparks, keep leads out of the way. The def do flood real easy. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 14, 2011 Share Posted August 14, 2011 sounds like what my mitsy done a few weeks ago and it ended up being fluded. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted August 15, 2011 Author Share Posted August 15, 2011 Would this cause the engine, cat and airbag lightto come on? Does the computer figure out that there is something wrong? From cranking rpm? Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted August 15, 2011 Share Posted August 15, 2011 try disconnect ecu overnight. may improve things/not do anything Quote Link to comment Share on other sites More sharing options...
DJZ Posted August 15, 2011 Share Posted August 15, 2011 4G swap, get rid of that Nissan junk. Quote Link to comment Share on other sites More sharing options...
twosmoke Posted August 15, 2011 Share Posted August 15, 2011 . Quote Link to comment Share on other sites More sharing options...
fuel Posted August 15, 2011 Share Posted August 15, 2011 the difference in viscosity of 5W50, 10W40 and 15W40 when cold at 0-10C will be negligible. Quote Link to comment Share on other sites More sharing options...
efp0wa Posted August 15, 2011 Share Posted August 15, 2011 enough jibba jabber, compression test Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted August 15, 2011 Author Share Posted August 15, 2011 Fuel 'n' Goose......On the money! Took a heap of attempts but eventually got it going. Had the Sigma with jumper leads on and cranked till it wouldnt crank no more. Each time the compression would get better. After about 30mins of trying it fired. Thanks heaps guys for the info and help! Much appreciated. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted August 16, 2011 Share Posted August 16, 2011 sweet, now give that thing an oil flush and a cuddle Quote Link to comment Share on other sites More sharing options...
