CaMpylobacter Posted February 22, 2011 Share Posted February 22, 2011 choice bro. get certed and skids on plz link to build thread viewtopic.php?f=17&t=26148 Quote Link to comment Share on other sites More sharing options...
Simon Posted February 22, 2011 Share Posted February 22, 2011 Not an M badge man but when it comes in those spec tyres you know it's a keeper. looking forward to good posts. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted February 22, 2011 Share Posted February 22, 2011 Sigma wagon at Avondale Pick a Part Still have a diff housing if you want it Logistics is the hurdle! Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 22, 2011 Author Share Posted February 22, 2011 beats the spitties it used to have Quote Link to comment Share on other sites More sharing options...
Truenotch Posted February 22, 2011 Share Posted February 22, 2011 Wow, another one!! ? Keen to see it in person... it's a completely different form of citrus. Quote Link to comment Share on other sites More sharing options...
Trigger Posted February 23, 2011 Share Posted February 23, 2011 MEAN bro! looks crisp as, how are the brakes? Quote Link to comment Share on other sites More sharing options...
Ogre Posted February 24, 2011 Share Posted February 24, 2011 Brakes are poo, like stepping in a cow turd like all starion brake conversions for some mystical reason.Gonna track it down and fix it, then maybe you could fix yours too lol. Just noticed it has braided brake lines in the front as well, they dont pass wofs do they? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 24, 2011 Share Posted February 24, 2011 they do if they have a safety marking tag on them Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 24, 2011 Share Posted February 24, 2011 yea they will pas a wof if they have a stamp or some form of identification saying they are ok and not some shithouse brand . this thing is awesoe ogre , amg it naow! keen to hear screamer *edit* smashed in the dickhole by kk Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 24, 2011 Share Posted February 24, 2011 this is definitely my hat now.. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 24, 2011 Author Share Posted February 24, 2011 has it had a larger bore master cylinder added? Quote Link to comment Share on other sites More sharing options...
Ogre Posted February 24, 2011 Share Posted February 24, 2011 nah, looks like standy one still on there.Pretty sure trigger seid he fitted his starion master and it was still poo. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 24, 2011 Share Posted February 24, 2011 Discs all round? If it is rear drums, is it factory LA and what is the bore size of the wheel cylinders? What is the bore size of the rear brakes on the parent car that the master cylinder came from? Quote Link to comment Share on other sites More sharing options...
Ogre Posted February 25, 2011 Share Posted February 25, 2011 LA currently has Drum rear, standard 19.05mm dia master, rear wheel cylinders dia are 19.01mm As yet to find specs on starion master etc.Starions are disc rear, so if i bung a starion master in and i stay with the drums int he rear of the LA is it gonna screw things up? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 25, 2011 Share Posted February 25, 2011 Yeah quite likely - most brake callipers have larger than 19mm bore pistons.. LOL you'll most probably end up locking the brakes constantly The Master CylinderSo, you have the right pedal leverage and have decided that you want the assistance of a power unit. Now it is time to look at your master cylinder. Back in the olden days, these were simple one-reservoir units that left much to be desired in both performance and safety. Today, master cylinders are packed with high-tech engineering and can make or break your system. Almost all the master cylinders used today are tandem units. This refers to the fact that they have two internal reservoirs: one for the front and one for the rear brakes. One important factor in choosing the right master cylinder is the volume of fluid it holds. For a high-performance system you want to make sure the unit will hold enough fluid to service your needs. More fluid means cooler fluid temps and extra insurance for extreme conditions where high pad wear can compromise fluid levels during extended performance driving events. Remember that as your pads wear down the fluid level in your master will also go down. Generally speaking, you need a larger master cylinder for bigger multi-piston brake systems, and you can go with a smaller, more OEM-sized unit for smaller systems. The master cylinder holds a good amount of fluid and looks pretty damn nice. When picking the right master cylinder for your ride, be sure to get one with the right bore size for your application.The most critical factor in master cylinder selection is bore size. Bore sizes can range from 5/8 inches upward to 1 1/8 inches or more. The bore size determines the amount of hydraulic pressure and fluid volume that will be sent downstream to the calipers. The actual amount of hydraulic pressure generated is based on the amount of force coming from the pedal or booster being divided by the area in square inches of the master cylinder bore. For example, a master cylinder with a 1-inch bore has .785 square inches or bore area. ( Bore x Bore x .785) If the pedal or booster delivers 500 pounds of force to the master cylinder, the hydraulic pressure will be equal to 500 divided by .785, which would result in 637 psi going to the lines. The displaced volume capacity is then based on the length of the available stroke multiplied by the bore area. It's the same formula that's used to calculate engine displacement for one cylinder. Generally speaking, if the master cylinder bore is too large, the driver will feel a very hard pedal feel with minimal pedal travel, and will have a difficult time generating the necessary pressure to effectively operate the brake system. If the master cylinder bore size is too small, the driver will be able to generate a lot of pressure, but the pedal may have an excessively long stroke or a very spongy feel. And if the bore size is way too small, the pedal or master cylinder may bottom out before enough volume is pumped to operate the calipers. The best advice would be to consult with the manufacturer of the brake system you will be using and work with them to pick the right size for your application. Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 25, 2011 Share Posted February 25, 2011 buy a brake bia adjustor? , i dont know the legalities of them , i do know workmates fj40 cruiser hd one and got certed so yea . Quote Link to comment Share on other sites More sharing options...
76lancer Posted March 20, 2011 Share Posted March 20, 2011 That thing looks bloody straight. Is the interior as good as outside? Have they painted over the chrome on the roof guttering? Quote Link to comment Share on other sites More sharing options...
