Antz's Toyota MarkTwooooo
Kelvin
Not as loud as an N/A car? Unsure, havent driven it yet, was getting wired today/2mrw, booked for exhaust next week + finish cooler piping as im redoing it for single turbo.
Should be rapid enough. Similar setups make around 200kw with just a y pipe and cheap t3/4. so should be heaps for me as im used to the 3hp 1ge.
Only problem is that i have no idea how im going to mount a decent sized exhaust under the car. The standard one is/gets destroyed and has been replaced every wof so far.. So basicly my cars to low. RS/Sedan life bitchs.
Wont be at nats. Decided to sink the money i would have spent on nats into this thing as i have pissed around long enough. NEXT YEAR.
  • Replies 248
Its way quieter than NA. I have straight 2.5 inch all the way from turbos with a hotdog at about the the drivers foot well. Doesnt drone at 100ks at all. Nice and loud outside of the car when you give it some shit but still quiet enough when you nanna it.
I had my exhaust all re-routed and got mods to my subframe done, I could have my car at 10mm and the exhaust wouldnt touch the ground. The chassis hits the ground first. If you dont go 3 inch you will be able to tuck the exhaust.
oh sweet! that means cheap exhaust also! ivgot offerd a single turbo setup.... still thinikng about it. brand new t3/t4 and a manifold. what do you have to change going to single turbo from twin? im new to all this turbo shiz. also what is this subframe mod you speak of?
I meant to take some pictures of the mod but can only do it on a hoist as car is too slammed to see under it haha. Basically there is a small factory notch in your rear suspension subframe where the exhaust passes under it. Get someone to cut out and reinforce this notch so the exhaust tucks right up into the subframe, so it essentially passes through it rather than under it. Allows you to get your exhaust sitting up real nice and high.
I am going to go single when I pop my twins. Y pipe/manifold + Turbo + Intake mods + Gen 3 1GGTE injectors = done.
2.5inch zaust is cheap. 3inch is all mandrel bends so is more costly. Considered 2x2 for clearance, but if theres so much room up in there then i may go 3. We shall see once its on the hoist. Dude is good and a mate so can spend time on it and get it all right.
My downspool shall own yours fresh.. xoxo. (i have blue bits for you also.)
interiors mostly back together, I made a new headlining for it the other week so hopefully it works out okay, its all stock turbos, exhaust, for this weekend then next week im going to swap in f series rear end, LSD, 2.5inch zaust, Y pipe(maybe single manifold i hope) and t3/4, external wastegate and then be too poor to afford the wof reg cert part. fml.
Yo Mitch, here, wire yo shit and do a 3 minute skid vid.
Y13648802921911164_1.jpg Y13648802921911164_2.jpg Y13648802921911164_3.jpg Y13648802921911164_4.jpg Y13648802921911164_5.jpg Y13648802921911164_6.jpg Y13648802921911164_7.jpg Y13648802921911164_8.jpg Y13648802921911164_9.jpg Y13648802921911164_10.jpg Y13648802921911164_11.jpg Y13648802921911164_12.jpg Y13648802921911164_13.jpg Y13648802921911164_14.jpg Y13648802921911164_15.jpg Y13648802921911164_16.jpg Y13648802921911164_17.jpg
EDIT: For future, This is the repinning of a factory manual gx71 1geu body loom plug to Gen 3 A/T 1ggte body loom plug.
Gay update. Basicly done nothing, except polish the shit out of it (need to finish bumpers) and hunt for the wheels i want. Not having alot of luck.
Need to get some lower arms lengthened in the front too.
Could go way lower in the front but needs skinnyer tyre's. Wheels will be for sale soon so not worth changing tyres. /14's
