Antz's Toyota MarkTwooooo
Kelvin
also, hardest thing was fitting the new bush in. just drill the old one around the crush tube until it is easyly hit out with a hammer, then press new bush in.
Nolathane have an online catalog for their bush's that you can search on sizes, i gave you the sizes in the project thread. maybe have a look online for the correct bush. should be under f100. if its not then there was like 3 i could have used so shouldnt be hard to locate one to work.
  • Replies 248
About that thermostat plumbing, it would pay to double check that you still have a suitable loop for the thermostat closed circuit (for warm-up before the thermostat opens) if you don't have this flow path you may find the engine coolant temp gets up but the thermostat doesn't open as it doesn't get a good flow of the warm coolant over the tail of the thermostat.
  • 10 months later...
Bought the gearbox with D/shaft and crossmember. Thats all.
Plan is Jun Flywheel, use the 1ggte's clutch as its new and slap it in.  Have to mod the speedo drive to accept W5# drive, crossmember, Shifter is the hardest part as its way back!
Then buy Mizuno Works headers before xmas With Michael as they sound amazing on a Redtop 1g.
