Hey guys
An opportunity to install an limited slip diff has presented itself and need to know what the options are/costs likely to be.
Going into 85 AW with silvertop conversion. Has C52 gearbox having full bearing and synchro replacement this week. Will be used predominantly as track car.
I understand that there are different types of LSD but know nout regarding the benefits/disadvantages associated therewith.
Any advice you guys can offer would be muchly appreciated.
Cheers
Chris
  • Replies 42
get a plate lsd and be done with it and get it set for 1.5 way it will be a bit more predictable than being 2 way . for serious track work that's the only thing id use . the standard viscous lsd in toyotas are ok (i have one in my supercharged trueno) but not as responsive as a plate type
Agreed. TRD plate types are the best and you can find parts to rebuild them.
The easiest option is to find an LSD c52 and put it in or a Torsen C56 from a superstrut AE111.
So the previous diagnosis was correct, bearings and synchro are toast but now I'm told that there is a bigger problem in that the Pinion shaft is munted.
Pinion shafts are apparently a million dollars so might need a new box altogether, Doh!
Does anyone have a pinion shaft? :?
you'l wanna get the crown wheel also, if you get a shaft. as running gears against each other with different amounts of wear, will be weaker. better off to buy another box, as above. they are cheap. when i was going thru a few c5* boxes i was just buying 4age boxes and swapping the internals into my case (starlet). mr2 boxes are slightly different to fwd ones arent they? so you could just do the same. syncos in them are pretty rubbish if you start abusing them, i found the later c56's a bit better, but still 2nd gear syncro was the first to give problems.
Hmmm,
Yes indeed, I know a guy with a box however cbf taking it out of his car for him.......... I've already done that once this week!
I will investigate replacement parts before committing to a new box as I know another guy whom just happens to be a parts guy. Should probably ask him bout the lsd too.
Also, it was 2nd synchro that was toasted.
Thanks for your help thus far :D
Lol'd at RRP $1000 for new pinion shaft ex japan. Dude, may still do a deal tho suspect better to get mates spare box as only has 120k on it and start from scratch.
Do that.
I gave away a C52 to thegreatestben.
The one in my car crunches all synchros, has pwnt reverse and chronic 5th gear pop out.
I'm going to fix it with E series LSD behind 3sgte.
Also look into a torsen LSD, they were factory in some later C boxes?
If the car is for the track 99% of the time a torsen will be quicker and nicer to drive, but no good for D1's. the clutch type feels 'better' as they have a more positive engagement and offers more fun
BTW - the going rate for an open diff C52 is $60ish, going rate for a Torsen C56 is $500+.
It's so worth it though.
I have driven one LSD'd AW11. Was in highschool, 5th form IIRC. Wet morning on a roundabout etc.
I fluked the sickest power oversteer and felt like mad mike.
Most memorable day of highschooling career.
$500's ok if you get a decent condition reasonable km box with it, its the superior LSD for track work. Verses $1000+ for a TRD clutch type for mad D1's like simon does after school
