eke_zetec_RWD Posted December 11, 2010 Share Posted December 11, 2010 hey, they run a inductive loop or something. whats the deal when i want to run from a low level drive? need help. chur Quote Link to comment Share on other sites More sharing options...
barf Posted December 14, 2010 Share Posted December 14, 2010 whats a 6 dial tacho? does it trigger from coil -ve? please explain? many if not most ECUs have a (separate) tacho output signal Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 14, 2010 Share Posted December 14, 2010 6 dial tacho is the tacho in a mk1 6 gauge dash Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 14, 2010 Author Share Posted December 14, 2010 6 dial tacho is the tacho in a mk1 6 gauge dash yea that, in factory form the power wire to the ignition coil runs through a loop in the rear of the tacho on its way to the coil. the pulsing of the current draw and the loop/coil induces a flux capaciator which spins the gauge needle! nah i dunno how it works but thats how its wired stock. the power wire isnt wired to the tacho it just passes through it. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 14, 2010 Share Posted December 14, 2010 Ring Robinsons Instruments they can change it to suit your needs.. (they did a mates tacho for $25 including freight and a wiring diagram) (I'll need to check if it was Robinsons but am reasonably sure it was..) Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 14, 2010 Share Posted December 14, 2010 speedo services in Auckland is also possible maybe, however that guy is usually dealing with reconning smith stuff Quote Link to comment Share on other sites More sharing options...
barf Posted December 14, 2010 Share Posted December 14, 2010 and what sort of tacho-output does your ECU have? distributor-style ignitino system? Quote Link to comment Share on other sites More sharing options...
Hemi Posted December 15, 2010 Share Posted December 15, 2010 so you are trying to use the ecu tacho output single to run the escort analouge guage? . had that prob with my hardtop so ill be keeping an eye on this thread . i just earthed the ignition coils signal earth through the input into the tacho ... works beaut but is a bit rugged Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 15, 2010 Author Share Posted December 15, 2010 link g3 ecu. single coil. ecu pulses a earth for tacho. low current so wont drive tacho. dnt want any coil power wires in cabin. Quote Link to comment Share on other sites More sharing options...
CXGPWR Posted December 15, 2010 Share Posted December 15, 2010 I can make u a device that runs from your ecu tacho out to this box, then from the box to your tacho, works well for me, i did it in the 82 Quote Link to comment Share on other sites More sharing options...
barf Posted December 16, 2010 Share Posted December 16, 2010 let me get this right: the tacho has two connections (from each end of the loop), and in and out so-to-speak that go between coil +ve and switched+12v? if so - this circuit should do the trick but, no guarantees, i'm just some guy on the Internet. it sounds like the tachometer is a current sensing circuit similar to some old Smith's gauges. this is a modification of the Megasquirt-style high-level tacho output circuit http://msextra.com/doc/ms2extra/MS2-Extra_Hardware.htm#tachoout for the dummy load, use at least a 5W wire-wound resistor (NOT carbon-film type!), start with a higher value and work your way down if there is nothing on the tacho (330,200,100,75,50,35,20 ohms). observe how much heat the load generates (not very scientific I know) you shouldn't have excessive heat. Quote Link to comment Share on other sites More sharing options...
