10Speed Posted January 30, 2010 Share Posted January 30, 2010 What best to use on the track? I have had bad fade at the end of my last 2 track days. As the pedal has felt soft until a complete flush I suspect I am boiling the fluid(?). Whats the best stuff available around here to use? Quote Link to comment Share on other sites More sharing options...
DodgySam Posted January 30, 2010 Share Posted January 30, 2010 I've always heard good things about ELF brake fluids. What kinds/grades etc i dont know but i shall find out for you. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted January 30, 2010 Share Posted January 30, 2010 Motul RBF 600 allegedly, but I've always just rolled Caltex shit from The Warehouse with no dramas. Quote Link to comment Share on other sites More sharing options...
DodgySam Posted January 30, 2010 Share Posted January 30, 2010 Have to a coupla mates who run track hacks and they all recommend... motul rb600 So yeah...what he said Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 30, 2010 Share Posted January 30, 2010 i used to get mean fade/boil in my clio. until i grabbed a bottle of motul 5.1 type stuff from the bike shop cheaper than high performance car stuff Quote Link to comment Share on other sites More sharing options...
fuel Posted January 30, 2010 Share Posted January 30, 2010 I used Castrol Super Dot 4 in the Eterna and did 4-5 trackdays before I started to get brake fade, but with the same fluid in my VR-4 I got brake fade within hours on the track. The previous owner used Motul RBF600 but I had to dump a bit of that out to remove a caliper and that's when I replaced it with Super Dot 4, have since done a full flush with Elf 5.1 brake fluid, cost about $50 for 500mL. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted January 30, 2010 Share Posted January 30, 2010 This reminds me of reading about some goat on an Alfa forum once who swore by draining the brake fluid out of his race car after every meet, filtering it, and heating it to boil off the water, then re-using it. Must've had heaps of moths in his wallet/was probably Burt Monroe's cousin. Also: http://www.drivenperformance.co.nz/scri ... roduct=710 Quote Link to comment Share on other sites More sharing options...
10Speed Posted February 3, 2010 Author Share Posted February 3, 2010 hmmm the motul stuff doesnt seem to be available in Ak at the moment... Have got some Penrite Sin 600 Plus Brake Fluid, I hear the Racebrakes guys use it in their race car... will let you know how it went after the nats. track day... and also have some fancy slotted rotors now Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 3, 2010 Share Posted February 3, 2010 Motul RBF is from BnT - I get mine for the Morrie from there - As a compare I have fanged round the track with this fluid and boosted brakes next to a buddy with same car (he has less hp and unboosted brakes) with road fluid and he got brake fade after 5 laps - I managed to do all 8 laps without any sign of fading.. Quote Link to comment Share on other sites More sharing options...
Spencer Posted February 3, 2010 Share Posted February 3, 2010 well the soarer never got fade on budget ferodo stuff this was with big sessions at taupo 25min+ sometimes. You will know if your fluids boiling you can see it, get the best pads you can afford, its usually the problem not the fluid. No ammount of awesome fluid will stop fade if your cars under braked in the first place The Motul stuff rules though Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted February 3, 2010 Share Posted February 3, 2010 I had silverline (repco) 5.1 in my aw11 at trackday, pretty cheap at $6 for 500ml and had no issues Quote Link to comment Share on other sites More sharing options...
10Speed Posted February 3, 2010 Author Share Posted February 3, 2010 http://www.racebrakes.co.nz/pdf/brake_upgrade.pdf great document... Quote Link to comment Share on other sites More sharing options...
Truenotch Posted February 4, 2010 Share Posted February 4, 2010 ^^ Is that the doc that tells you which fluid etc to run? It's a good read when you're first getting into it. RBF600 is the go IMO. It's $29 retail per bottle and is pretty damn good.... Or RBF660 if you want to spend a bit more. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 4, 2010 Share Posted February 4, 2010 well the soarer never got fade on budget ferodo stuff this was with big sessions at taupo 25min+ sometimes. You will know if your fluids boiling you can see it, get the best pads you can afford, its usually the problem not the fluid. No ammount of awesome fluid will stop fade if your cars under braked in the first placeThe Motul stuff rules though heartily agree. got minimal spongey pedal in the poojet with cherry red rotors and 3year old fluid. Quote Link to comment Share on other sites More sharing options...
