repowered Posted December 4, 2009 Share Posted December 4, 2009 on behalf of cleavelandsteamer (he has no net this weekend due to moving house) we installed a stereo in his '78 xc falcon and it drained the batt overnight for some reason. we charged the batt fully but it wont turn over just clicks, i think its the starter solienoid. Hes supposed to be moving house 2moro and needs to get the car from upper ricc to hei-hei so any help would be appreciated from anyone in the chch area. please contact Graeme on 0276792450 Cheers! Quote Link to comment Share on other sites More sharing options...
Hemi Posted December 4, 2009 Share Posted December 4, 2009 on behalf of cleavelandsteamer (he has no net this weekend due to moving house) we installed a stereo in his '78 xc falcon and it drained the batt overnight for some reason. we charged the batt fully but it wont turn over just clicks, i think its the starter solienoid. Hes supposed to be moving house 2moro and needs to get the car from upper ricc to hei-hei so any help would be appreciated from anyone in the chch area. please contact Graeme on 0276792450 Cheers! clicking is the starter solinoid exciting but once the power to the actual motor is made it sucks all the powe instantly = flat batt. just jump start it and move it ....if it keeps draining the batt talk to a sparky inclined person ...there are heaps here .. could explain now but im somwhat compromised Quote Link to comment Share on other sites More sharing options...
EFI_LC Posted December 4, 2009 Share Posted December 4, 2009 Check for loose connections from the starter to the battery as well... did the leads from the battery come off? as this is a common cause as well if they are loose. If that fails try a screwdriver directly across the starter motor contacts so it bypasses the solonoid in case it has shit itself but my quick guess if the battery has charge is loose connection somewhere. Quote Link to comment Share on other sites More sharing options...
repowered Posted December 4, 2009 Author Share Posted December 4, 2009 he remembered he's an aa member.... called them and they found a faulty relay. i think they just bypassed it or something to get it going so all sorted, thanks Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 4, 2009 Share Posted December 4, 2009 They would have just jumpstarted it with a jump-pack, I imagine. That clicking from the solenoid was just an insufficient amount of voltage to fully engage and subsequently spint he starter motor. Faulty relay my ass. Get that stereo wiring sorted properly so it doesn't drain the battery. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 4, 2009 Share Posted December 4, 2009 ^this Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 4, 2009 Share Posted December 4, 2009 P.S. I worked for a place that was contracted to Roadside Assist for AA, STATE, etc, etc. I've heard my fair share of clicking flat battery calls. This sounds exactly as such and you even have a reason for it. Open and shut case. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted December 5, 2009 Share Posted December 5, 2009 If you ever short the starter out with a screw driver to make it crank over ALWAYS make usre you aint in gear 1st. More than one person has been killed this way in days gone by. Quote Link to comment Share on other sites More sharing options...
Mike-e Posted December 5, 2009 Share Posted December 5, 2009 ^and more than one person in days gone by has lold at retards who start shit in richard gear Quote Link to comment Share on other sites More sharing options...
repowered Posted December 6, 2009 Author Share Posted December 6, 2009 na we were jumping it off my car an still would just click, turns out the AA guy told him to just disconect a wire near the battery (i think i went to that relay) and touch it on the battery to get it to crank. Quote Link to comment Share on other sites More sharing options...
clevelandsteamer Posted December 6, 2009 Share Posted December 6, 2009 yip wasnt a battery issue, have 2 disconenct a wire and start it that way while touching it on ther ed of the battery, i baught a new relay and pluged t in same places as it was, But that has not fixed the issue, in the daylight after work im gona double check the wires make sure they are all good (could be a fucked or loose one) Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 6, 2009 Share Posted December 6, 2009 How did you have the jump cables connected? Quote Link to comment Share on other sites More sharing options...
repowered Posted December 6, 2009 Author Share Posted December 6, 2009 Just terminal to terminal, jump started another time ok the aa dude used his battery pack on it and still just clicked. Quote Link to comment Share on other sites More sharing options...
clevelandsteamer Posted December 6, 2009 Share Posted December 6, 2009 battery was not an issue. startd 1st pop when touching the wire to battery Quote Link to comment Share on other sites More sharing options...
