repowered
Everything posted by repowered
  1. yea me and cleavo in his XC will be keen
  2. was just rolling past down blen rd at lunch time. that hole should we bring some shovels and just pile some dirt in there?
  3. cheers for the info man. also saw you today as well CLUB8R / I forget your real name
  4. could be keen...see if i can russell up clevelandsteamer
  5. Hey hey Just see if there are any Electricans floating around here that want to wire up a Weiss Heat Transfer fan. Ive installed it in the celing already but not really confident with the old 240v system and wiring it up. I was going to try get it to work off the hall light but the wires for it just go straight from switch board through the celing into the light, no fitting to screw wires to in the celing like modern houses. Might require some wiring, I have spare switch we could use. hopefully pretty easy job. Can compensate in bevis or $$ was hoping to pay under $80, guessing a proper sparky would be about $150-200
  6. yea thats it sorry, had it in my head it was after the river when you come out of the twisty coast bit.
  7. lol yea ! hard to see on google maps but its here http://maps.google.co.nz/maps?f=q&source=s_q&hl=en&geocode=&q=kaikoura&sll=-41.244772,172.617188&sspn=32.660422,56.162109&ie=UTF8&hq=&hnear=Kaikoura,+Canterbury&ll=-42.433114,173.589322&spn=0.001964,0.005472&t=h&z=18
  8. always see that when I go up there, is just after the bridge over the river before kaikoura. its pretty small and tight but looks fun, always wondered if it was accessable. few hours from chch though, mean drive around the sea before kaikoura.
  9. repowered
    4age help
    hmm 4500 is when the tvis opened though, the controls for that are under the inlet mani, i think its ecu controlled though - Pin 10 on middle ECU plug Red/White see http://www.club4ag.com/faq_and_tech_pages/ECU%20Japan%20AE86%204A-GE.htm may not be this though. will find that check engine light stuff now
  10. repowered
    4age help
    this is my old car .....never missed a beat for me untill I sold it to this guy afew weeks ago :S yep is map sensed, only issue i can think this might be is: the guy i got to do splice/joining of looms didnt do a very good job and i had to tape the loom up where it went into ECU so it didnt jiggle over bumps ect as it caused engine 2 cut out. i would idle but died when you put foot on gas. but he said to me it wouldnt idle but did with TPS unplugged. ..........But I had it taped in a sweet spot and it hadnt been a issue for me for about 2 years! Just remembered I have a spare ECU somwhere i think man let me know if you want to try it.
  11. not sure what pub, someone mentioned wheatsheaf / too far away that time of night prolly. what about just roll 2 speights ale after yarns / max arkwardness? ill be rolling with clevo on this one. my old 30 may be making an appearance though! :S is it 6 or 6.30?
  12. firestone sounds good for max visa...visi...viz...visability...viza mmmmmm did you say you were suppling beers club8r!
  13. akaroa map route, home via lyttelton tunnel hasnt been done as a cruise by Os for a while, i havnt driven it for about a year so k33n!
  14. yep there! / hunted I spied you driving past St Georges hostp last night
  15. k33n!, you wont be able to can't see aformentioned lawnmowers from there though
  16. yea I might go for a look, usualy just park up most of the time.
  17. ah must be another white delta around then! They wouldnt be that common in NZ would they? sweet about ball joint spiltter, will see if i need it once i pull the arm off
  18. Guts about inside out dents, When got the 30 it had them from a rouge sizzor jack. MrGoose did I see your Lanica on trailer being towed by a hiace on sunday? curlets rd ect.. ????
