m0ss4yy Posted November 29, 2009 Author Share Posted November 29, 2009 only if you wish to get your car lower than factory bump stop height seen so many people talking about bump stops and shit, wtf is it? Link to comment Share on other sites More sharing options...
bubblegoose Posted November 29, 2009 Share Posted November 29, 2009 bit of rubber that 'softens' the sudden stop of running out of suspension Link to comment Share on other sites More sharing options...
m0ss4yy Posted November 29, 2009 Author Share Posted November 29, 2009 and where is this rubber located? Link to comment Share on other sites More sharing options...
bubblegoose Posted November 29, 2009 Share Posted November 29, 2009 somwhere on the chrome bit of your shock, may be incorporated into a dust cover Link to comment Share on other sites More sharing options...
m0ss4yy Posted November 29, 2009 Author Share Posted November 29, 2009 also called a stop tube? or are they just those little rubber bushes? Link to comment Share on other sites More sharing options...
m0ss4yy Posted November 30, 2009 Author Share Posted November 30, 2009 Okay so i know i need to find somebody in auckland area who can shorten shocks, or make new ones up Link to comment Share on other sites More sharing options...
bubblegoose Posted November 30, 2009 Share Posted November 30, 2009 Okay so i know i need to find somebody in auckland area who can shorten shocks, or make new ones up doubt you will find somebody to make you a shock and pay less than $2k Link to comment Share on other sites More sharing options...
m0ss4yy Posted November 30, 2009 Author Share Posted November 30, 2009 Really? i thought it wasnt that expensive? Link to comment Share on other sites More sharing options...
davidian Posted November 30, 2009 Share Posted November 30, 2009 Okay so i know i need to find somebody in auckland area who can shorten shocks, or make new ones up Autolign, Carbine rd, Mt Welly ask for Ian edit: cant be arsed going back trough the jizz but you will either find a shorter shock from another car with same mounting style or shorten your own one. Ian will sort you either way Link to comment Share on other sites More sharing options...
m0ss4yy Posted November 30, 2009 Author Share Posted November 30, 2009 Okay so i know i need to find somebody in auckland area who can shorten shocks, or make new ones up Autolign, Carbine rd, Mt Welly ask for Ian edit: cant be arsed going back trough the jizz but you will either find a shorter shock from another car with same mounting style or shorten your own one. Ian will sort you either way Sweet man, thanks, might give that 1 a go Link to comment Share on other sites More sharing options...
Gaz Posted December 1, 2009 Share Posted December 1, 2009 shit and i thought everyone was over the cut spring bullshit years ago its cheap and still makes the car low.. why not? Because it is illegal!!! We dont condone cutting of springs here. Dont be a cheap ass and do it properly... You can either get custom springs made up to suit current shocks or you can get shocks and springs made up. Or you can cross reference your spring diameter with other makes/models and then goto the kingspring manual. The cheapest option is to find some kingsprings that will fit $200 a pair. Then get your current SHOCKS machined down $100 so it keeps the spring captive. Those are your options. Ring your local spring maker to get more info on making springs as he should be able to make you something that will remain captive using the standard shock .. You can find him in the yellow pages under spring maker. Thanks, Bye. Link to comment Share on other sites More sharing options...
m0ss4yy Posted December 1, 2009 Author Share Posted December 1, 2009 yea but wats the problem with cutting them and captivating them?? basically the same as having kings in there really i wud never cut springs and leave them flopping around.. im gonna do mine peoperly anyway, springs and shocks make up, and shoren shocks.. extra leaf in the springs at the back and reset them Link to comment Share on other sites More sharing options...
anhonyb Posted December 1, 2009 Share Posted December 1, 2009 yea but wats the problem with cutting them and captivating them?? worse handling cos isnt enough force spread out in the cut spring or something Link to comment Share on other sites More sharing options...
m0ss4yy Posted December 1, 2009 Author Share Posted December 1, 2009 yeh theres many reasons as to why thers worse handling.. many Link to comment Share on other sites More sharing options...
mikuni Posted December 2, 2009 Share Posted December 2, 2009 yup, cut springs are bad. very very bad. never do it, never. getting some rough bastard down at a spring shop to grab a bit of spring steel, cut it to the required length and taper the ends is different because it is called "custom springs" and costs a lot more than cutting the standard springs Link to comment Share on other sites More sharing options...
Gaz Posted December 2, 2009 Share Posted December 2, 2009 yea but wats the problem with cutting them and captivating them??basically the same as having kings in there really No it isnt. If you look at your spring you will see that the top coils are differant and flatten off making them sit in the top cup and locate propely. Cutting them means they dont do this anymore. Gaz Link to comment Share on other sites More sharing options...
Borgweiser Posted December 2, 2009 Share Posted December 2, 2009 http://retrorides.proboards.com/index.c ... 503&page=1 Read thread and do what others have done = win Link to comment Share on other sites More sharing options...
durty Posted December 2, 2009 Share Posted December 2, 2009 yea but wats the problem with cutting them and captivating them??basically the same as having kings in there really No it isnt. If you look at your spring you will see that the top coils are differant and flatten off making them sit in the top cup and locate propely. Cutting them means they dont do this anymore. Gaz maybe for your cars boe, my car has springs that dont flatten off at all and the top/bottom hats are shaped to accomosate no taper. I have cuts from the front of a commodore or something i grabbed from pick a part, are shorter stiffer and perfectly captive, what is the problem with my car Link to comment Share on other sites More sharing options...
Gaz Posted December 2, 2009 Share Posted December 2, 2009 I know some cars that is the case. For the majority of cars they are not like this. GHaz Link to comment Share on other sites More sharing options...
MRT1TRD Posted December 2, 2009 Share Posted December 2, 2009 anyone have any ideas on where i can get shocks made up or a better way of doing it? Call Chris at 'Suspention tech' 0272145325 He is the best shock guy in town and will help you get the setup you need tho he would wantyou to go for bilstens as they the best. Link to comment Share on other sites More sharing options...
