HighLUX Posted August 20, 2009 Share Posted August 20, 2009 Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted August 20, 2009 Share Posted August 20, 2009 Haha someone finally bought it. It's been on trademe for AGES Quote Link to comment Share on other sites More sharing options...
UTERUS Posted August 20, 2009 Share Posted August 20, 2009 Holy lols i was just thinking the same thing, double up the swaybars and roll it to an os trackday ftw. Still rollin the teins in the rear? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 20, 2009 Author Share Posted August 20, 2009 Yea been eyeing it up for a while still got coil overs with plenty of adjustment left would be a choice trackday wagon, has a lush interior il be keen to bring it for a blast needs lsd, has plenty of 1 wheel delight atm when you give it some stick not to keen on the paintjob but itl do for now want it to be a sleeper so looking for O.G colour to paint it and some steelies with toyota hubcabs Quote Link to comment Share on other sites More sharing options...
UTERUS Posted August 20, 2009 Share Posted August 20, 2009 Only lsd option with the E series is via the closest arc welder Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 20, 2009 Author Share Posted August 20, 2009 going to check out a f series lsd swap from 4x4 townace and some better brakes possibly as old owner rekens it could pull up better but will see once I get a good drive in it Quote Link to comment Share on other sites More sharing options...
UTERUS Posted August 20, 2009 Share Posted August 20, 2009 If you do go f series i'm keen to aswell, then be all omg ace drifting. Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted August 20, 2009 Share Posted August 20, 2009 please create ace drifting team Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 25, 2009 Author Share Posted August 25, 2009 no pics yet as the weather has been shite,will try get some in the weekend is a great daily lush as to drive goes great loves to rev but really needs lsd asap, are 4x4 townace diffs leafsprung or trailing arm? and does anyone know where one could be?? the rear swaybar hits the driveshaft under hard acceleration and makes an loud bang so need to fix that,any ideas? any toyota knowledgeable people have any ideas on a brake upgrade for the front end to get it pulling up a bit quicker? Quote Link to comment Share on other sites More sharing options...
Simon Posted August 25, 2009 Share Posted August 25, 2009 want it to be a sleeper so looking for O.G colour to paint it and some steelies with toyota hubcabs Was filled with joy reading that as it was precisely what i was thinking looking at the photo. Go hard! Will be so sweet on the track! Quote Link to comment Share on other sites More sharing options...
HighLUX Posted September 1, 2009 Author Share Posted September 1, 2009 The van developed a strong gas smell over the weekend so havnt been driving it, pulled the engine covers off tonight to check for fuel leaks and found that the fuel line was worn from rubbing on the cover so fixed that, should be better on gas now Nice long runners on the intake plenum, looks like a good piece of workmanship nice welds In other news, picked up f series diff from a masterace surf 4wd, should bolt straight in me hopes once I get a LSD is sorted for it, grabbed the swaybar aswell because it has a notch for the driveshaft so will slap that in and will fix the issue of the driveshaft hitting the sway bar Quote Link to comment Share on other sites More sharing options...
HighLUX Posted September 11, 2009 Author Share Posted September 11, 2009 Whipped out the old swaybar this arvo and swapped it for the masterace item. Bolted straight in but had to change the links as the 4wd ones were longer. Driveshaft still hits the new swaybar but not as much as the old one, bushes are shagged so will replace them soon and hopefully that will fix it. 4WD swaybar vs 2WD swaybar(4wd is the top 1) Also scored a momo steering wheel and bosskit for $10, got the gearshifter boot redone and scored a fire extinguisher for free Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 23, 2009 Author Share Posted November 23, 2009 Was driving home from tairua in the weekend and heard a pop, pulled over expecting to find a flat tyre but found this Bottom shock mount has cracked and broken off which sent the tein into the road bending it slightly(should straighten out) then into the rim taking out a nice chunk of it. So out came the rangimods to get home Still bowling round with it like this till I get the mount re welded tomorow Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 23, 2009 Share Posted November 23, 2009 I was wondering when this was going to happen, suprised it took this long But really, stink thing to happen really. Are you going to brace the mounts? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 23, 2009 Author Share Posted November 23, 2009 Yea ohwell things happen. Yep will get them beefed up when I get it fixed Quote Link to comment Share on other sites More sharing options...
lowlancer Posted November 23, 2009 Share Posted November 23, 2009 Saw you parked up in the gorge, wheel off. Were you caning all over the show? Saw you like 5 times Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 23, 2009 Author Share Posted November 23, 2009 Yep had been doing fairly spirited driving all weekend Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 23, 2009 Share Posted November 23, 2009 should start a 'i fixed it thread', your stick spec tein can go 1st Quote Link to comment Share on other sites More sharing options...
HighLUX Posted December 17, 2009 Author Share Posted December 17, 2009 Hmmm E series diffs aint to happy with receiving clutch kicks Yum yum! spider gear soup anyone? Will get the f series in as soon as funds permit Chucked some new shocks in the front aswell Whats the deal with double swaybar setups? Quote Link to comment Share on other sites More sharing options...
Mike-e Posted December 17, 2009 Share Posted December 17, 2009 tis a fucking rough way to get less body roll Quote Link to comment Share on other sites More sharing options...
