d.p.n.s Posted June 24, 2009 Share Posted June 24, 2009 hi all ive got a mates pedal box to copy for my escort thanks (steve) and i was going to use one of these for the clutch matser cylinder http://www.trademe.co.nz/Browse/Listing ... =226228415 but my qeustion is do you think it would be enough to do the brakes if i use one for the front and one for the rear? cheers dan Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 24, 2009 Share Posted June 24, 2009 What do you mean 'enough'? If you are talking about the reseviour then they may be OK but you would be better with a M/C that accepts a remote reseviour as the ones you are looking at are going to be hell hard to fill with fluid if they are under the dash. Have you made a wheel cylinder/bore size selection yet? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 25, 2009 Share Posted June 25, 2009 http://www.keepandshare.com/doc/view.php?id=617294&da=y The way this ones been done the cylinders are at quite an angle as UJ pointed out Where can you get the bias pedal adjustable thread bit in NZ? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 25, 2009 Share Posted June 25, 2009 In saying that looking at QCADTA's box they can be made to work So how do you go about working out what size you require? Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 25, 2009 Share Posted June 25, 2009 what calipers you gonna run? in my stocky i use xf falcon front calipers,a piddly toyota rear caliper (1), and wrx master cyl..15/16" bore.. my clutch is a hydraulic throw out bearing type and is powered by a trojan type trailer master cyl.. works a treat.... Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 25, 2009 Share Posted June 25, 2009 In saying that looking at QCADTA's box they can be made to work So how do you go about working out what size you require? I wonder what the plan is for topping up the fluid.DOT 5.1 I bet! Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 25, 2009 Share Posted June 25, 2009 Not sure what d.p.n.s is running. Im planning on ae92 calipers to the rear and austin princess to the front. With hydraulic clutch (Mazda Cosmo 5 speed box) Dont really know were to start Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 25, 2009 Author Share Posted June 25, 2009 im running mk2 discs up front 9" drums on the rear and the 5 speed in hydraulic clutch this is steves (sholdowa)one i have to KEEP i mean copy lol made from a mk1 pedal box im just going to make the same and there is room for one more master cylinder for the clutch and the just run 3 bottles on top. dont know what sort of hoses to run with it ? dan Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 25, 2009 Share Posted June 25, 2009 Oh sorted! need more pics Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 25, 2009 Share Posted June 25, 2009 Unless you are on a very strict budget have a think about using the same M/Cs as as Sholdowa. They are not that expensive and you may get some second hand. I buy them new from Les Hunter in Christchurch for about $58 each I think. He also sells the remote reseviours. I have some used ones I could sell but you will need to know what bore size you want first. My shit v Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 25, 2009 Share Posted June 25, 2009 will milk contaners with a home in the bottom do as reseviours? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 25, 2009 Author Share Posted June 25, 2009 Unless you are on a very strict budget have a think about using the same M/Cs as as Sholdowa.They are not that expensive and you may get some second hand. I buy them new from Les Hunter in Christchurch for about $58 each I think. He also sells the remote reseviours. I have some used ones I could sell but you will need to know what bore size you want first. My shit v thats what ill do then mate what did you use for the hoses? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 25, 2009 Share Posted June 25, 2009 d.p.n.s were are you getting your balance bar from? Just been looking around for one and had no luck still Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 25, 2009 Author Share Posted June 25, 2009 d.p.n.s were are you getting your balance bar from?Just been looking around for one and had no luck still think palmside.co.nz still do them for about $110 mate cheers dan Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 25, 2009 Share Posted June 25, 2009 The hoses are fuel line I think. Les sold it to me but he also told me I could just use somthing else but I can't remember exactly what the alternative was. You want me to go have a look at the workshop and let you know what hose type it is? Quote Link to comment Share on other sites More sharing options...
sholdowa Posted June 25, 2009 Share Posted June 25, 2009 Oy I want that back!!! I remember these cylinders costing 8 quid back in the UK... Girlings cheapest! Any idea where to get the bits to convert that one from cable to hydraulic clutch?? Quote Link to comment Share on other sites More sharing options...
filthy one Posted June 25, 2009 Share Posted June 25, 2009 Big D i can get these mate they come off tractors we sell i used them on my wagon {hence the pics } I can find out the cost if ya want mate Ps i used a S1 RX7 master cylinder duel circuit came with a res & the fittings to remote mount it from BNT $120 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 25, 2009 Share Posted June 25, 2009 auto brake n clutch in palmy, less than 40 each trade. recomend 5/8th for road car. make own resivour or one from a van. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 25, 2009 Share Posted June 25, 2009 auto brake n clutch in palmy, less than 40 each trade. recommend 5/8th for road car. make own resivour or one from a van. 5/8 for clutch? sweet just so happen to have one in my workshop form the surf ... how do i know if i purchased something like this; http://www.trademe.co.nz/Browse/Listing ... =225996301 if it will match 5/8" mater cylinder? have asked him but got a feeling he wont know. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 25, 2009 Share Posted June 25, 2009 it depends on what you put it on. pretty much just try it lol. if you dnt hav enough stroak at clutch then u need bigger master and vise versa Quote Link to comment Share on other sites More sharing options...
