peteretep Posted April 9, 2009 Share Posted April 9, 2009 im going through the rewiring for my escort, I was wondering what is usually powered by the 'on' position, do I need anything else apart from coil, oil pressure switch and fuel pump? and do things like interior light go in here too or nah? and just for interest, the ignition switch only can contact 2 of the 4 positions at once, so when you are starting, the 'start' and 'on' positions have power to them, and once you have started and released the key, it will sit in the 'on' and accessory' position another electrics while starting question, does anyone know why my starter motor has 3 pins on it? it is a pre-engaged type, it has one large terminal for permanent power, and a spade for the starting switch but also a smaller threaded terminal which doesnt seem to contact with anything else Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted April 10, 2009 Share Posted April 10, 2009 a smaller threaded terminal from memory thats for a ballast setup....but my memory is also old and prone to misinformation Quote Link to comment Share on other sites More sharing options...
sholdowa Posted April 10, 2009 Share Posted April 10, 2009 not this time. It's the 12V feed for the coil on starting. Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 10, 2009 Share Posted April 10, 2009 a smaller threaded terminal from memory thats for a ballast setup....but my memory is also old and prone to misinformation not this time. It's the 12V feed for the coil on starting. Ballast = 12v feed to coil during starting Quote Link to comment Share on other sites More sharing options...
sholdowa Posted April 11, 2009 Share Posted April 11, 2009 a smaller threaded terminal from memory thats for a ballast setup....but my memory is also old and prone to misinformation not this time. It's the 12V feed for the coil on starting. Ballast = 12v feed to coil during starting ... which is why I was pointing out that Mackaz's memory was perfect this time Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2009 Author Share Posted April 13, 2009 what is its purpose? do i need it if theres another cable running to the coil +? Quote Link to comment Share on other sites More sharing options...
forced Posted April 13, 2009 Share Posted April 13, 2009 It's so that while cranking the coil gets 12V direct from the starter. Once running the coil gets a lower voltage from the ballast resistor. Steve Quote Link to comment Share on other sites More sharing options...
Yowzer Posted April 13, 2009 Share Posted April 13, 2009 It just gives a fatter spark for easy starting. Not really a necessity, haven't got it plugged in on the hillman and it still fires sweet. As for the rest of the wiring, just chuck anything needed for running on the 'on', and all the less important stz on the acc. Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2009 Author Share Posted April 13, 2009 ok, i had not thought about that, if i have a gt40r coil, and am redoing my wiring, i will need a new ballast resistor? where do you get one that does the job? i regret buying a new points distributor Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 13, 2009 Share Posted April 13, 2009 gt40r is internally resisted from memory. Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2009 Author Share Posted April 13, 2009 it says "12v ignition coil, use with resistor" on it Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 13, 2009 Share Posted April 13, 2009 lol then use it with a ballast. I knew it was one or the other. Gt40 is the internally resisted then. Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2009 Author Share Posted April 13, 2009 does repco sell ballast resistors? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 13, 2009 Share Posted April 13, 2009 Yep Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2009 Author Share Posted April 13, 2009 i will investigate tomorrow so i'll have a wire going to the coil + via the 'on' switch with a ballast resistor in it, and a seperate wire going form the 12v feed on the starter to the coil + for starting Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 13, 2009 Share Posted April 13, 2009 I would do away with the ballast altogether and run a 12v coil on a relayed 12v feed. Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2009 Author Share Posted April 13, 2009 yeah but it would just start jumping around inside the dizzy and fuck with the timing and slowly destroy the contacting points Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 13, 2009 Share Posted April 13, 2009 What?? Quote Link to comment Share on other sites More sharing options...
Ke36 Posted April 13, 2009 Share Posted April 13, 2009 yuh ballast resistor just drops down the 12v feed so you dont burn your points out real quick Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 13, 2009 Share Posted April 13, 2009 I always ran all of my old Fords (and Datsun/minis/Mazdas/KE's etc) with no ballast at all and never once had problems with burnt points. Quote Link to comment Share on other sites More sharing options...
