peteretep Posted April 14, 2009 Author Share Posted April 14, 2009 i quite like the cheapdude idea, and shit, its not like i cant change it later Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 14, 2009 Share Posted April 14, 2009 I have not read all the above posts but a Subaru Leone distributor will go into your block after a bit of surgery (to the dizzy) and gives you electronic ignition in one fell swoop. I think they are about $30 from PaP and a noob could modify it to fit in about 4 hours and with about $4 of parts (just a roll pin and an angle grinder blade) Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 15, 2009 Author Share Posted April 15, 2009 just bought one of these, give it a go http://www.jaycar.co.nz/productView.asp ... BCATID=347 Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted April 15, 2009 Share Posted April 15, 2009 ^yea thats the one I was talking about. Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 18, 2009 Author Share Posted April 18, 2009 hey im going through this jaycar thing, its pretty cool, but anyway, its main use is to work with the jaycar programmable ignition, so there ends up being two ways of putting it together, one way has 3 transistors and the other only has 2. For the second setup, it says "it is changed to 'fire' a plug when the input signal goes high", what does this mean? also in the second setup, it says "With this arrangement, the coil "charges" when the input signal is low & "fires" a plug when the signal goes high" Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 19, 2009 Author Share Posted April 19, 2009 anyone? i dont know what it means when it says the input signal goes high or low. it also calls the second setup "positive-edge firing" what does this mean? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted April 19, 2009 Share Posted April 19, 2009 I'd throw a guess to say that the high input signal would be a pulse from the dizzy? Other then that, I don't really know Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 19, 2009 Author Share Posted April 19, 2009 yeah ok i built this thing on the second setup, anyone with points wanna giz me there car to try it out , if i break anything on your car i'll replace it Quote Link to comment Share on other sites More sharing options...
