solidstripe Posted December 13, 2008 Share Posted December 13, 2008 Two problems for you to show of your vast awesomeness on... 1) The mysterymobile doesn't like turning off after the key turns off. It'll sit there and cough and splutter for a bit before it dies or I'll stall it on purpose to hurry it up. Had a total fit outside the bakery the other day after I turned the key off and hopped out, and just stood there for ages as it was coughing and hopping... was rofl's galoore! Anything I can do to remedy the situation? 2) The rear drivers side brake locks up super easy. Even at 30-40 km's it'll scretch for ages down the road rolling up to a intersection with slight to moderate pressure on the brake pedal. It want's to vear right when it does it so I presume it's the drivers side locking up and skidding while the passengers side still rolls. Going on a couple of roadys over the holidays and don't particlary want it locking up all over the show. Any idea's? Churrs! Quote Link to comment Share on other sites More sharing options...
tortron Posted December 13, 2008 Share Posted December 13, 2008 1. carbon deposits on piston - these stay hot and will ignite the fuel or your timings out a bit 2. pull rear wheels off and scope out the brakes - probably a ceased piston/cylinder or has been adjusted poorly Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted December 13, 2008 Share Posted December 13, 2008 sounds like some one wheel braking Quote Link to comment Share on other sites More sharing options...
Hemi Posted December 13, 2008 Share Posted December 13, 2008 1.carbon deposits on piston - these stay hot and will ignite the fuel or your timings out a bit 2. pull rear wheels off and scope out the brakes - probably a ceased piston/cylinder or has been adjusted poorly too higher idle will do it too Quote Link to comment Share on other sites More sharing options...
sholdowa Posted December 13, 2008 Share Posted December 13, 2008 1. Carbon on the valves ( yeah I know, but it's a quote from a book written by James Bonds brther ) Take it out and rev the bollocks off it for half n hour or so. Should burn it off. 2. Piston on the rear passenger side wheel is siezed? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 13, 2008 Share Posted December 13, 2008 1 = High Idle, Advanced Timing, Carbon Deposits, Vacuum Leak I would reset the idle to 750rpm, set the timing to 8 degrees advance 2 = Brake Contamination, Maladjusted Brakes Remove the rear brake drums, check for leaks or damaged brake shoes, clean the dust out (with water is best) and adjust the rear shoes properly That is all Quote Link to comment Share on other sites More sharing options...
solidstripe Posted December 13, 2008 Author Share Posted December 13, 2008 Cheers y'all, yeah the timing's not the flashest, so it will probebly be that. Will take the gun to it. And will get someone who know's what their doing to look at the brakes (brakes aren't my strong suit). Quote Link to comment Share on other sites More sharing options...
solidstripe Posted December 14, 2008 Author Share Posted December 14, 2008 Turns out I'm not that good at electrics either (why don't I take up knitting or something instead?!), the engine won't start now. All the electrics run fine (sunroof, sounds, fuel pump etc) but the engine won't turn over. What the hey? Why won't it turn? No spark? Quote Link to comment Share on other sites More sharing options...
Requiemk Posted December 14, 2008 Share Posted December 14, 2008 If its not turning over like cranking give your startermotor/tap with a hammer Quote Link to comment Share on other sites More sharing options...
tortron Posted December 14, 2008 Share Posted December 14, 2008 did you take the leads off the battery? i find with the chevette that unless they are put back on real tight itl turn over slow/not Quote Link to comment Share on other sites More sharing options...
forced Posted December 14, 2008 Share Posted December 14, 2008 Your wheel that's locking up, probably a leaking cylinder and brake fluid all over the shoes. Steve Quote Link to comment Share on other sites More sharing options...
solidstripe Posted December 14, 2008 Author Share Posted December 14, 2008 I'll give the starter the bash in the morning or rock it in gear. Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted December 15, 2008 Share Posted December 15, 2008 RE: Runon Old esky did this, new plugs & leads and reset the timing and she ran mint (till it blew up) Quote Link to comment Share on other sites More sharing options...
solidstripe Posted December 24, 2008 Author Share Posted December 24, 2008 OK, NEW PROBLEM, URGENT HELP NEEDED: as I'm off camping tomorrow morning bright and early. My van wasn't turning over so got a new battery, that wasn't the probelm, so mechanic said I need a new starter, choice. Problem fixed for about a week. Now it's got the same problem back (all electrics running, fuel pump whirring etc, but won't turn over and start up). Push starts fine. But the indicators only blink once now, the lights are a bit dim, the horn is really quiet and my cd player's turning off and on. (mostly off) Any idea's what the problem is? Surely if it's the starter motor again, it wouldn't make these electric things go funny? I need help urgently! If anyone has any ideas, please let me know!! Fuse? Dodgy wiring? Earthing? Starter? Alt? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 24, 2008 Share Posted December 24, 2008 Sounds like a dodgy earth bro. Check the - terminal to chassis Quote Link to comment Share on other sites More sharing options...
FLAWLES Posted December 25, 2008 Share Posted December 25, 2008 Sounds like a dodgy earth bro. Check the - terminal to chassis would agree combined with alt would do that low voltage would poo the armerture in the starter proberly way to late now anyway Quote Link to comment Share on other sites More sharing options...
forced Posted December 25, 2008 Share Posted December 25, 2008 Maybe the alternator has no output. Easy to check with a multimeter. Steve Quote Link to comment Share on other sites More sharing options...
