durty Posted November 20, 2008 Share Posted November 20, 2008 thats definately a slant 4 i reckon, i really cant see another bank but i can see hoses where it should be Quote Link to comment Share on other sites More sharing options...
Jay GTi Posted November 20, 2008 Share Posted November 20, 2008 Ah but... the engine is canted over to it's left (looking front on) which gives the appearance of a missing bank, look down though, sitting pretty much behind the alternator, is what looks like another valve cover... Quote Link to comment Share on other sites More sharing options...
Raizer Posted November 20, 2008 Share Posted November 20, 2008 I agree, that's a Chev diesel V8. Look at the right bank you can see the metal fuel lines running to the injectors same as in the pic posted by Jay GTi Quote Link to comment Share on other sites More sharing options...
xsspeed Posted November 20, 2008 Author Share Posted November 20, 2008 Ah but... the engine is canted over to it's left (looking front on) which gives the appearance of a missing bank, look down though, sitting pretty much behind the alternator, is what looks like another valve cover... Exactly what I was looking at, if you zoom right in you can almost see another branch of the inlet manifold. The block (if its there on the left) appears to have surface rust as opposed to oil/grime, giving the appearance its not there. trying to find a left hand pic of the chev v8 diesel but its highly likely that the bank of cylinders are offset behind the alternator. Comparing the right hand side to that pic of the 6.5 diesel, they are scarily similar. Oil lines, oil feed, valve cover etc Quote Link to comment Share on other sites More sharing options...
Raizer Posted November 20, 2008 Share Posted November 20, 2008 It is later model but its the same block etc as the older ones Quote Link to comment Share on other sites More sharing options...
durty Posted November 20, 2008 Share Posted November 20, 2008 i still cant see it aye, looking at the block around the pullys i cant see it extending on the other side maybe im just blind Quote Link to comment Share on other sites More sharing options...
fuel Posted November 20, 2008 Share Posted November 20, 2008 check out my l33t photoshop skillz Quote Link to comment Share on other sites More sharing options...
kyteler Posted November 20, 2008 Share Posted November 20, 2008 Cheers Phil. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted November 21, 2008 Author Share Posted November 21, 2008 Haha, mean paint erm, photoshop skills Quote Link to comment Share on other sites More sharing options...
slipsittin Posted November 23, 2008 Share Posted November 23, 2008 If it is a chev diesel the injector pump is located in the distributor hole. I was with Durty thinking it was a slant 4 Ford D series truck engine but I'm not sure now?? Corey Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted November 23, 2008 Share Posted November 23, 2008 I still think its a slant 4 from that pic. Depth perception tells me this Quote Link to comment Share on other sites More sharing options...
xsspeed Posted November 25, 2008 Author Share Posted November 25, 2008 OK so while TGB might not be, I am pretty certain it is a 6.2l chev diesel v8. The 6.5's had the black valve covers, and this one is mor elikely than not and older engine. Examples can be seen in these trademe auctions: http://www.trademe.co.nz/Browse/Listing.aspx?id=178039784 http://www.trademe.co.nz/Browse/Listing.aspx?id=187406200 http://www.trademe.co.nz/Trade-Me-Motors/Cars/Chevrolet/Silverado/auction-187818188.htm Quote Link to comment Share on other sites More sharing options...
kyteler Posted November 25, 2008 Share Posted November 25, 2008 Score then! Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted December 8, 2008 Share Posted December 8, 2008 Dig up old post. Meh. That wont be a 6.5 diesel. thats a small block so it will be a 5.7..... still sweet diesel donk though.....you can tell by exhaust port lay out. if the two "middle" ports are together its a small block. If they are spaced apart evenly (all 4 per bank) tis a Big Block ie 6.2 or 6.5, applies to Chev petrol and diesels... Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 8, 2008 Author Share Posted December 8, 2008 Oh sweet cheers for the info, will check out the exhaust when I get down there again. And BTW cheers in advance for details on that HZ lip Quote Link to comment Share on other sites More sharing options...
