xsspeed Posted December 17, 2014 Author Posted December 17, 2014 are you sure it doesnt need a HolleyTM speeno? puhuhuhu I'd be keen on that I always get technicians to do all the tool work anyway Quote
CaMpylobacter Posted December 17, 2014 Posted December 17, 2014 have you considered a deisel for this? 1 Quote
kyteler Posted December 17, 2014 Posted December 17, 2014 have you considered a deisel for this? 4D56 Clearly. Quote
xsspeed Posted December 17, 2014 Author Posted December 17, 2014 Lol even that 6.2 wouldnt have been considered. Bloody mongrels that could have part funded a 454 Quote
AllTorque Posted December 17, 2014 Posted December 17, 2014 There is some dude who makes bolt in 9"ers for HQ/X/Z by using a 9" nugget and centre housing and using the axle tubes from a HQ/X/Z Salisbury diff. All apparently for a reasonable price. I can try and ask more details next time I see JB but that may not be for a month or so. I have been told this works.Holden tubes, axles, brakes. Quote
Rookie Posted December 17, 2014 Posted December 17, 2014 LOL, fuck off, he is going sploder diff and redrilling the axles which is a half hour job. Quote
xsspeed Posted December 17, 2014 Author Posted December 17, 2014 You'd still tell me im wrong if i did what you say dave 4 Quote
kyteler Posted December 17, 2014 Posted December 17, 2014 He's not wrong that you would be wrong though. You should ruck his face. (there's no possible way to be right, bee tea uu) Quote
Rookie Posted December 17, 2014 Posted December 17, 2014 Price up a 9 inch and then come back to me; I spent ages trying to convince Tom to go fabbed 9 inch in his POS, but the numbers just don't work. Quote
xsspeed Posted December 17, 2014 Author Posted December 17, 2014 Assuming i have a 9 inch housing to go with these two 9 inch diff heads and the holden live axle diffs I already have I can see the merit in doing as kk and all torque suggest but I will just weigh it up and decide. Good to have the options Quote
CaMpylobacter Posted December 17, 2014 Posted December 17, 2014 IF I PRICE IT CAN I COME ON YOUR BACK PLEASE DAVID? Quote
Spencer Posted December 17, 2014 Posted December 17, 2014 Assuming i have a 9 inch housing to go with these two 9 inch diff heads and the holden live axle diffs I already have I can see the merit in doing as kk and all torque suggest but I will just weigh it up and decide. Good to have the options Assuming you can get a sploder diff as cheap as I did the whole diff will cost you less than a LSD/spool for a 9" 1 Quote
Spencer Posted December 17, 2014 Posted December 17, 2014 8.8 diffs are the new K24/LS2 of the diff world. 2 Quote
Spencer Posted December 17, 2014 Posted December 17, 2014 As I said most of them are, I checked out 6 of them looking for bargains and they were all LSD. Prices here ranged from $300-$600, pretty sure more people have cottoned on to them as a few wreckers knew what they had. Get the D shaft if you can for the mounting UJ/flange on the diff end also. Get cam to price you one. 8.8's are what ford replaced the 9" with in 1986, they came out in 1 billion mustangs so have stacks of aftermarket stz if needed. Oh check your stock diff width also as I have no idea, don't want to chuck one in and get all be all KK spec Quote
The Dude Posted December 17, 2014 Posted December 17, 2014 $140 for an exploder diff at Zebra! end to end! 1 Quote
Spencer Posted December 17, 2014 Posted December 17, 2014 Ok there are a couple of caveats if you go diff hunting. You want a 94-ish up one as it has disc brakes and some real POS spec ones have a 7.5" diff which you don't want. LSD ones should have a tag on the rear cover, but I found that if they have ever had the oild changed (you need to drop the rear cover to do it) then the tag is normally missing. I would drop the rear cover on any diff I bought before paying money and check the LSD. 1 Quote
CaMpylobacter Posted December 17, 2014 Posted December 17, 2014 $140 for an exploder diff at Zebra! end to end! fuck a man where he pees from. that's sweet 1 Quote
Rookie Posted December 17, 2014 Posted December 17, 2014 $140 for an exploder diff at Zebra! end to end! Holy shit, you wouldn't even get the UJ for a 9" for that hahaha Quote
