Gaz Posted May 6, 2008 Share Posted May 6, 2008 Just went to save Chris as his car was broke. Drove home with only full throtle jammed on, wasnt so fun haha. Anyways. 2l pinto, 32/36 webber downdraft. Linkages are all free. using the linkage on the carb I can squirt fuel and fully open both butterflies. Both butterflies are in closed position as should be when no linkages are being touched by me... I.e the linkage is returning to closed position Prob is.. turn key and engine just revs like a fucker.. no matter if you pump the gas or fiddle the linkages?? WTF can this be? Quote Link to comment Share on other sites More sharing options...
fuel Posted May 6, 2008 Share Posted May 6, 2008 could be a massive vac leak? if you cover both the throats does the engine stall or does it keep revving? Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 6, 2008 Author Share Posted May 6, 2008 I almost tried covering them then got phonecall and forgot. Will try now. Vacum from carb comes from booster. Quote Link to comment Share on other sites More sharing options...
Vai-Man Posted May 6, 2008 Share Posted May 6, 2008 i had a similar problem with a 32/36, but only when it was hot so i don't know if it helps much. But it was a gasket and a hairline crack when heated up it expanded the crack(also happend on a 63 tiger my dad had but with a head) wasn't quite full throttle though. But check all the vacuum likes and the butterfly's as well. It must be an air leak or such because if it was fuel it would just flood. manifold maybe? probly a long shot though. Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 6, 2008 Author Share Posted May 6, 2008 Ok problem fixed. Secondry butterfly had one of the screws missing so it was'nt quite closing. Made alot of revs for such a small gap the air could get through! Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 6, 2008 Share Posted May 6, 2008 Thanks for rescuing me Gaza your my hero i can now contine low n slow n 5min fix in the end just wiped carb off in the dark a few washers and nuts were lost in the battle. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 6, 2008 Share Posted May 6, 2008 Haha i like the destresed "HELP" in the heading was exactly how i felt amoungst the confusion. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 6, 2008 Share Posted May 6, 2008 It will most prolly be a missing screw from the secondary`butterfly Flap flap. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 6, 2008 Share Posted May 6, 2008 It will most prolly be a missing screw from the secondary`butterflyFlap flap. Yup Yup, that's exactly what it was. Luckily the screw didn't drop down the manifold. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted May 6, 2008 Share Posted May 6, 2008 Yeah do you know where the screw is? Pop out the top or something? Ugly if it did go down the manifold. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 6, 2008 Share Posted May 6, 2008 Yeah do you know where the screw is? Pop out the top or something? Ugly if it did go down the manifold. We are fairly confident we saw it drop down the engine bay as the carb was removed from the manifold however we cant be certain as it was dark. Gaze said you would hear straight away if it was in there loving life :S Quote Link to comment Share on other sites More sharing options...
pies Posted May 6, 2008 Share Posted May 6, 2008 I reckon its a missing screw from the secondary`butterfly Quote Link to comment Share on other sites More sharing options...
sheepers Posted May 6, 2008 Share Posted May 6, 2008 when i read the title of this thread i lol'ed, i thought "OMG!! he's driving down the road with the throttle wide open desperately typing on his laptop asking for help" laugh i did!! Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 7, 2008 Author Share Posted May 7, 2008 when i read the title of this thread i lol'ed, i thought "OMG!! he's driving down the road with the throttle wide open desperately typing on his laptop asking for help"laugh i did!! haha on my fast and furious motec laptop Prob pull plugs out and wind it over tonight incase it is down there tho. blow the cunt out... Im sure if it was down there we would know bout it by now tho Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 7, 2008 Share Posted May 7, 2008 Are they a brass screw? If not then a magnetic pick-up down there may be a better idea. Also: Come to my wkshop for beer tonight after 8pm. Bring the cat. EDIT: I will model my new steelcap boots for you. Thanks R-Bubz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 7, 2008 Share Posted May 7, 2008 Are they a brass screw?Also: Come to my wkshop for beer tonight after 8pm. /quote] .... Oops Sorry just saw this ... we just had a work on gazza's car night ... went well going to be done in no time honest! Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 7, 2008 Author Share Posted May 7, 2008 Screw is brass Quote Link to comment Share on other sites More sharing options...
twisted Posted May 7, 2008 Share Posted May 7, 2008 Screw is brass Vaccum cleaner & home fabricated cardboard attachment. worked on my 'rona when the sparkplug shattered. Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted May 8, 2008 Share Posted May 8, 2008 had this on the eski before, on mine one of the springs snapped that returns the second throat to normal position. in other notes i reckon 7000rpm will sort the screw out. but maybe its thinking like this which is why i cant get my car going Quote Link to comment Share on other sites More sharing options...
Jay GTi Posted May 8, 2008 Share Posted May 8, 2008 Dropped an aircleaner nut into the carb on my old KE36, I knew it was in there because the engine turned 1/2 a revolution and then locked solid. If something has dropped down into the engine, you'll know. Quote Link to comment Share on other sites More sharing options...
