NewGuy Posted October 10, 2007 Share Posted October 10, 2007 Diff oil? Just been checking my brakes and grease nipples etc over and thought shit i better check the diff oil. had the car jacked up pulled the plug out. Fuck all diff oil. Whats should i use? I have transmission oil? Quote Link to comment Share on other sites More sharing options...
Testament Posted October 10, 2007 Share Posted October 10, 2007 diff oil? its usually an EP oil of some description. e.g. Castrol EPX 80W-90 Quote Link to comment Share on other sites More sharing options...
NewGuy Posted October 10, 2007 Author Share Posted October 10, 2007 diff oil? its usually an EP oil of some description. e.g. Castrol EPX 80W-90 Hmmm ok thought i could be a cheap cunt and use my trans oil. Quote Link to comment Share on other sites More sharing options...
Testament Posted October 10, 2007 Share Posted October 10, 2007 your trans oil might be EP, it is sometimes. but sometimes its just engine oil, depends on the trans. Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 10, 2007 Share Posted October 10, 2007 your trans oil might be EP, it is sometimes. but sometimes its just engine oil, depends on the trans.He's got an auto boe so I'd guess its ATF aye Quote Link to comment Share on other sites More sharing options...
NewGuy Posted October 10, 2007 Author Share Posted October 10, 2007 your trans oil might be EP, it is sometimes. but sometimes its just engine oil, depends on the trans. Ill have to hunt down my cars manual lol. At work somewhere fucking cleaner moved all the books etc. Been looking for it ever since. Quote Link to comment Share on other sites More sharing options...
NewGuy Posted October 10, 2007 Author Share Posted October 10, 2007 Fuck all these ratings drive me insane lol Lol in my book in my dream i was told to use Castrol GTX oil for everything including brakes, diff engine auto box lol. cheapest dream ever. your trans oil might be EP, it is sometimes. but sometimes its just engine oil, depends on the trans.He's got an auto boe so I'd guess its ATF aye Quote Link to comment Share on other sites More sharing options...
NewGuy Posted October 10, 2007 Author Share Posted October 10, 2007 SAE 90EP Extreme Pressure hypoid Oil. Quote Link to comment Share on other sites More sharing options...
NewGuy Posted October 11, 2007 Author Share Posted October 11, 2007 Me brought some, i wonder how much of a difference it will make. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted March 21, 2008 Share Posted March 21, 2008 I'd use EP 90. Whatever you do, don't get it in your hair unless you like the greasy look for the next month. Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 21, 2008 Share Posted March 21, 2008 yeaits good to have ep due to the way the diff pinion and crown slide against each other , normal oil tends to squeeze out in these circumstances Quote Link to comment Share on other sites More sharing options...
sheepers Posted March 21, 2008 Share Posted March 21, 2008 the stuff you want is HP90. mongol is onto it, the pressure in between the crown wheel and the pinion is immense, wrong oil = fail. edit; the gears dont "slide" at all, they have a continuos rolling contact but the contact patch is very small hence the huge pressure. HP stands for high pressure. this is to do with the oil's shear strength and its ability to hold a film under extreme load. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted March 21, 2008 Share Posted March 21, 2008 I'm not certain HP'll cut it. EP = extreme pressure... Quote Link to comment Share on other sites More sharing options...
Guest sexychevette Posted March 22, 2008 Share Posted March 22, 2008 I'd use EP 90. Whatever you do, don't get it in your hair unless you like the greasy look for the next month. omg yuh. i laydown in a puddle of the stuff whilst worken under a mates car. Could not get that shit out of my hair. Washed it like 10 times that night Quote Link to comment Share on other sites More sharing options...
mint16 Posted March 24, 2008 Share Posted March 24, 2008 Some good oil is Hy Tran oil. Go in to a Case IH tractor place should be one near you. And ask for Hy Tran oil. I highly recommend for diff. NO WAY!!! that oil is too thin, and is quoted on the label as suitable for 'tractor transmissions and final drives', not differentials!!! i saw the aftermath of your diff after using that oil, no way would i recommend that oil! stick with the tried and true method of using factory recommended diff oil with the right viscosity. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted March 24, 2008 Share Posted March 24, 2008 Gear oil is smelly shit. I got some on myself once. I ended up throwing away the top I was wearing under over overalls. Fuck I hate the shit. Sythetic stuff doesn't smell as bad. Quote Link to comment Share on other sites More sharing options...
