Treggo's Mk2 Capri.
treggo
  • Replies 135
At the moment: rebuild bottom end, I've scored some oversize pistons rings and shit for a hundred bucks new so stoked about that. Will give the head a little port, match port the manifolds and run the 38dgas jetted to suit. Will be okay for a daily i guess. And further down the track I plan to run some sort of rev happy 6.
Guest sexychevette
mrs makita, makita and me. i use balck and decker. You should do a body drop and chop and channel(i have no idea what that means).
Also you should ad a turbo on that pinto. Was talkin to this guy last week about his turbo pinto capri and it sounded pretty ruthless.
Oh forgot. Lowered front end, tis a bit lower but no nearly low enough so have to sort that out now :rolleyes: Also anyone know a cheap place to get get leafs reset?
Snells Springs in aux reset and lower leaf springs to your specs for $210 a pair and do custom coils for i think $200 a pair.
