My name is Russell Posted April 28, 2008 Share Posted April 28, 2008 Deal now we just need to set a Venue and time Quote Link to comment Share on other sites More sharing options...
QCADTA Posted April 29, 2008 Share Posted April 29, 2008 And a tow back to invercargill if i blow the cunt up. Quote Link to comment Share on other sites More sharing options...
Fordy19 Posted May 5, 2008 Share Posted May 5, 2008 Kit includes2 x PBR twin piston front calipers 2 x UPC#040, 296mm x 28mm vented rotors 2 x UPC#1344, Police spec brake pads 2 x Custom made ADR 7/00 braided brake hoses 2 x Escort adaptor hubs made from K1045 billet steel complete with bearings, seals & studs High tensile bolts are supplied to fit the kit Kits from melbourne and bolts straight up. Will work out way cheaper and look better than going down the ap path with redrilledhubs etc. Just waiting to hear back bout the price for shipping. Not to worried though, i just want them Hi, would be very very grateful if you could please tell me what company supplies these kits and what to ask for. Am I right in understanding these hub kits bolt up to the standard struts, racks and sway bar or do those need to be changed as well? Quote Link to comment Share on other sites More sharing options...
Fordy19 Posted May 5, 2008 Share Posted May 5, 2008 Also was wondering if you had to shorten the axles/diff housing at all from the hilux? I am looking at diff options and I have a set of arches to slap on mine. Kinda tossing up between the hilux or coon diff's, have also aquired a v4 capri diff already modified for the old mk1 but dont think it will stand up to the reverse to firsts I have planned. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted May 6, 2008 Share Posted May 6, 2008 Hi there, as long as you get the right model diff (rn10 - 25) it will bolt straight in. Theres a good post i put in the tech section about converting an escort to hilux setup. http://www.competitionengineering@optusnet.com.au This is the companys email who sells the brake setup, and it all bolts straight up, comes with everything you need. Not that cheap though, think it was bout $1500 all up. Just tell them what model esort/struts you have. They fucked the offset of my hubs up when they machined mine but are sending new ones so have apparently fixed this problem. Youll also need to run 15" mags minimum. Quote Link to comment Share on other sites More sharing options...
Fordy19 Posted May 6, 2008 Share Posted May 6, 2008 Thanks heaps for that information, I appreciate it! Am totally enjoying following your project, Quote Link to comment Share on other sites More sharing options...
nobumps Posted June 9, 2008 Share Posted June 9, 2008 love the contrast of the two colours, Great build keep it up Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 9, 2008 Share Posted June 9, 2008 Interesting new pics. Is your sump standard? I moved my engine back alot as where it was sitting before meant I had no room for a fan behind the rad. You look to have alot of room. Almost as much as I have now that I have moved it back. How have you mounted it? Straight of the original escort mounts and then onto the ca mounts or moved it forward or...??? Also the black with the orange looks mintastic! Bolt on gaurds also great idea.. Small radiator also A great idea.. Looks small, honda small infact? Gaz Quote Link to comment Share on other sites More sharing options...
QCADTA Posted June 9, 2008 Share Posted June 9, 2008 love the contrast of the two colours, Great build keep it up Cheers mate, helps the dwindling enthausiasm Interesting new pics.Is your sump standard? I moved my engine back alot as where it was sitting before meant I had no room for a fan behind the rad. You look to have alot of room. Almost as much as I have now that I have moved it back. How have you mounted it? Straight of the original escort mounts and then onto the ca mounts or moved it forward or...??? Also the black with the orange looks mintastic! Bolt on gaurds also great idea.. Small radiator also A great idea.. Looks small, honda small infact? Gaz Yeah its a standard sump with standard engine mounts on a near standard escort xmember, just cut down the escort xmember posts so they were lower and welded new plates to them. Spot on with the radiator its a honda two core full alloy one, just gota mount an electric fan to it. Seen a '69 boss mustang racing at teretonga with the black on orange theme so pinched that idea from there. Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 9, 2008 Share Posted June 9, 2008 Seen a '69 boss mustang racing at teretonga with the black on orange theme so pinched that idea from there. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 9, 2008 Share Posted June 9, 2008 Yeah its a standard sump with standard engine mounts on a near standard escort xmember, just cut down the escort xmember posts so they were lower and welded new plates to them. Oh real. Wonder why mine is differant. Before I had the engine on a crossmember I brought. It had the mointing points moved forward from the escort pillar 3.5inch. He told me that was so if would fit in the standard engine bay. Ive now moved it back 4 inchs to above the original engine posts. My sump will noway fit tho, hits the steering rack big time. Id be interested to see more, maybe pics and some measurements? Maybe from the front of engine to the very front rad panel. or rear of engine to the front of that grill. Chur. I might get one of those same rads but the 3core version. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 9, 2008 Author Share Posted June 9, 2008 shes looking fukin awsome mate you should be proud of yourself you have done a realy nice job her so far. that honda rad fits nice and should keep it cool my old mazda had one and i never had any problems with heat. have you chose some rims yet? dan Quote Link to comment Share on other sites More sharing options...
QCADTA Posted June 10, 2008 Share Posted June 10, 2008 Cheers dan, the photos are probably a bit flattering havent decided fully on wheels yet,but whatever they are theyll be deep dish. Gaz, will have a look at some measurements next time im in the garage (if i remember), i did cut my g/box tunnel slightly and moved the original mounting point so the g/box fitted up there a bit better. Quote Link to comment Share on other sites More sharing options...
Guest bazcort Posted August 26, 2008 Share Posted August 26, 2008 what condition are ya princess callipers mate? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted August 26, 2008 Share Posted August 26, 2008 theyre in need of a full rebuild, and ap callipers areheavy as fuck.have you considered these options Volvo Calliper With Capri Turbo Disk Conversion or BMW E28/Mazda RX7 Brake Conversion or Volvo Caliper with E30 Disk Brake Conversion Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted October 31, 2008 Share Posted October 31, 2008 fucken awesome choice of rims dude. this is gonna look so bangin once done. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted October 31, 2008 Share Posted October 31, 2008 Cheers mate, just deciding on what colour to paint the centres, trying a dark metallic silver but thinkin along the lines of gloss black, dunno anyone with any ideas of tyres that will stretch over 15 x 9s? cheers Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted October 31, 2008 Share Posted October 31, 2008 195/45 will be sweet. i rekon a gunmetal/black will look mean against the orange Quote Link to comment Share on other sites More sharing options...
treggo Posted October 31, 2008 Share Posted October 31, 2008 Favorite project Quote Link to comment Share on other sites More sharing options...
QCADTA Posted October 31, 2008 Share Posted October 31, 2008 best i get it back on track then engine will hopefully be back in timorrow, found it easier to wire with it out, and i thought the engine had seized but turned out it came with the wrong starter motor upon further analysis ive changed my mind again and the rims will have black centres. thinink 205/50 for tyres, maybe Quote Link to comment Share on other sites More sharing options...
