d.p.n.s Posted August 29, 2007 Share Posted August 29, 2007 thats coming along so well mate. the motors a nice fit aswell. thats what i want to do with mine archs the bubbles are mean. if you dont mine me asking mate where did you pick the front panel and bubbles from and how much? with the rad suport gone theres so much more room now and that race civic rad will fitin there nicly. and your right about that intercooler its a perfect fit for the front so i have to ask bro whats the dimentions may have to get me one all in all i love it mate so keep the pics and up dates coming all ive managed to do to mine is fully strip and i got the gaurd off and the bodys not to bad but i want to get it sand balsted fully before i start. and im have such a problem picking amotor. its between small block v8,sr20det,or the one i think ill end up going with rb25det. but mymind changers all the time. dan Quote Link to comment Share on other sites More sharing options...
mikuni Posted August 29, 2007 Share Posted August 29, 2007 and im have such a problem picking amotor.its between small block v8,sr20det,or the one i think ill end up going with rb25det. but mymind changers all the time. dan Have you considered going with Toyotas 2.5L 1JZ-GTE. It is a better engine that the RB25DET and is cheaper at the moment too because of the Nissan drift buz. For abit of inspiration as to how good it looks and fits in older stuff; http://www.oldschool.co.nz/phpbb/viewtopic.php?t=9806 Ps, sorry to thread jack QCADTA. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 29, 2007 Author Share Posted August 29, 2007 and im have such a problem picking amotor.its between small block v8,sr20det,or the one i think ill end up going with rb25det. but mymind changers all the time. dan Have you considered going with Toyotas 2.5L 1JZ-GTE. It is a better engine that the RB25DET and is cheaper at the moment too because of the Nissan drift buz. For abit of inspiration as to how good it looks and fits in older stuff; http://www.oldschool.co.nz/phpbb/viewtopic.php?t=9806 Ps, sorry to thread jack QCADTA. yeh ive thought about it but i didnt know that they are cheaper . thats a good thing. Quote Link to comment Share on other sites More sharing options...
sheepers Posted August 30, 2007 Share Posted August 30, 2007 1JZ FTW!!!!!! Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 30, 2007 Author Share Posted August 30, 2007 1JZ FTW!!!!!! what? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 30, 2007 Author Share Posted August 30, 2007 just to get back on track this topic isnt about me. so if its to do with me post them on my project. this is about this mint escort being built. cheers dan Quote Link to comment Share on other sites More sharing options...
QCADTA Posted August 30, 2007 Share Posted August 30, 2007 cheers dan. thanx for the encouragement! I got da intercooler off trade me. The dimensions are 450x300x76mm. With 90deg silicon joins it should fit perfect behind the grill. The front panel is from palmside, http://www.palmside.co.nz/ as for the bubblrs theyre another score off trade me. Will hunt out some old emails for you and maybe give you an address. Fook me an RB25DET is a big under taking! Youll have to chop alot out of your firewall, and have about a foot long drive shaft! Heres some reading for you. http://classicford.mine.nu/forum/topic.asp?TOPIC_ID=10538 Good luck with ya build to mate, ill be following it closely, itll be a ripper if you pull it off! Just a couple of pics from this link. Quote Link to comment Share on other sites More sharing options...
Guest sexychevette Posted August 30, 2007 Share Posted August 30, 2007 choice conversion! Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 30, 2007 Author Share Posted August 30, 2007 cheers dan. thanx for the encouragement! I got da intercooler off trade me. The dimensions are 450x300x76mm. With 90deg silicon joins it should fit perfect behind the grill. The front panel is from palmside, http://www.palmside.co.nz/ as for the bubblrs theyre another score off trade me. Will hunt out some old emails for you and maybe give you an address. Fook me an RB25DET is a big under taking! Youll have to chop alot out of your firewall, and have about a foot long drive shaft! Heres some reading for you. http://classicford.mine.nu/forum/topic.asp?TOPIC_ID=10538 Good luck with ya build to mate, ill be following it closely, itll be a ripper if you pull it off! Just a couple of pics from this link. thanks mate that was a ggod read ive put a 4.1 ford 6 in befor and they are huge and it was a bodge job to thrash around. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 30, 2007 Author Share Posted August 30, 2007 thats some nice work on the firewall mate. what sort of pedal box are you thinking of using? Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 30, 2007 Share Posted August 30, 2007 Ya just going to bung the radiator behind the cooler? Im running a small honda turbo one down the bottom, think 400x150x90.. Is still too long to get the pipes off it bending without cutting the side walls. Does yours have 90's sticking straight out the front? Whyya running such a huge cooler tho? What turbo you going to run? Not much room up the front of the little mk1's aye. Was trial fitting my cooler other day and no way of fitting how I wanted it! Might cut that lower huge peice out and put box section back in. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted August 31, 2007 Share Posted August 31, 2007 Yeah not much room at all! Im using 90deg silicon joiners wich do fit and im running a full alloy race radiator from a honda civic. My first ca18 has got a GT28 turbo, 510cc injectors, s/s manifold, apexi safc etc, and my second prepped up engine has a bigger high mount T3 turbo and an ex/wastegate if room allows, so thats what da bigger intercooler is for, and since the car is stripped i thought i might as well over compensate for further plans, dont think this car will ever be truely be finished! Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 31, 2007 Share Posted August 31, 2007 Oh fair call. Sounds similar to my ca. Gt28r, 510 evo jectors, wastegate, BOv, filter cooler etc shit. Remapped ECU. You going for round the 200kw marks then? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 31, 2007 Author Share Posted August 31, 2007 sounds like a nice motor set up mate. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted August 31, 2007 Share Posted August 31, 2007 Yeah that would be good. Probably be enough in a wee car like the mk1......well for now anyway! Hows your build coming along? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 31, 2007 Author Share Posted August 31, 2007 Yeah that would be good. Probably be enough in a wee car like the mk1......well for now anyway! Hows your build coming along? slowly man if i had more cash left over each week id be and you know how it is man i need things to do other things. like i need a skyline motor and box so i can cut the wall and tunnel and make new.(so if anyone has a motor even a fuked rb20turbo and box i can use just do mock up the wall and tunnel pm me) but all in all mate its stripped and waiting Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 31, 2007 Share Posted August 31, 2007 You should bag 200kw easy with the GT28r. Maybe even 220 if tuned right etc. Ya looked into using the remapped Ecus on trademe? He can do one set up for the GT28 with all sorts of modes.. even the Ca16 cam. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted September 1, 2007 Share Posted September 1, 2007 Yeah seen them on there. Mite have to get one once i know my exact setup. Hope fully the internals hold up to the extra power! If not, theyre still making engines! Know of anyone who has tried one? Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 1, 2007 Share Posted September 1, 2007 haha yeah sounds like your doing exactly what I am. As for people that have tried them.. i was going to ask you teh same thing. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 5, 2007 Author Share Posted October 5, 2007 lookinh good mate. was it a bitch to unpick the strut plates? and the bubbles look mean man heaps of room under there now a dan Quote Link to comment Share on other sites More sharing options...
