nobumps
nobumps last won the day on April 9 2013
nobumps had the most liked content!
nobumps's Achievements
Advanced Member
Advanced Member (3/5)
15
  1. Its still alive, Sneak peak Uploaded with ImageShack.us
  2. Actual pics of your car would be better then I can show you what it will look like with inverting those colours etc.
  3. Thats sweet for design, but will need pics of your car. Side/front/rear
  4. You still wanting sticker work done? Send me some pics one day and i can layout the design you want, got the gear at home to do it now.
  5. por 15 metal reday it is, cheers
  6. Im leaving a few large areas in bare metal for a few weeks, whats the best product to use to protect until ready to prime?
  7. Painting alloy inlet manifold, cam covers etc. Block will be left alone just cleaned up
  8. Anyone got any recomendations on what paint to use? Currently im trying VHT Flame Proof etch primer and using the VHT Flame proof top coat and then baking in the oven. Has anyone used this product? Im not entirley happy with the outcome has come out very chalky.
  9. nobumps
    etch priming
    If its just been sanded through on the edges or nothing bigger than say a old 50cent cent coin, dont worry about it just prime as normal.
  10. Anyone got a half decent shed or something I could paint a car in. I got all the gear just lacking somewhere. It wouldnt be for a few weeks yet.
  11. just wet the shit out of the walls floor etc and keep it wet youll be all good
  12. yup so its fully protected, can clean etc, its not dull its just got a nice sheen not a shine, Ive only done jams etc
  13. If your spraying clear you wont need to flatten your base, get your mettalic base spray that as per usuall, then spray 2/3 clear coats then on your last 1/2 coats of clear thats when you add your flattning agent, you only need a small amount otherwise it will go to grey,(try a test panel first), try your best to miminize overspray as stated before, you wont beable to cut it out, Ive done the same with a champagne met and it came out mint
  14. I seens it. I reakon seal bog/metal with a etch then tint a primer your guna get best (cheapest) results that way, theres no real way to go about it unless you fork out and do it proper. otherwise it'll just look like a usless c**t painted it.
  15. Have had a few probs in the golf my igniter fucked out got it replaced now the car is limiting at 3000rpm. Could the coil pack/ignitor be the wrong one for the car? or has a sensor fucked out somewhere. Any ideas? all plugs seem to be fine will check for corosion freyed wire etc tonight.
