crispymk2 Posted August 12, 2007 Share Posted August 12, 2007 Hey, just a quick noob stz question... I've blown up my gearbox and for removal the workshop manual says to drain the box and also the radiator/cooling system too... Do I really need to drain the coolant as well or should I be right? it's a 1600 x-flow & 2000E g/box cheers Quote Link to comment Share on other sites More sharing options...
Mike-e Posted August 12, 2007 Share Posted August 12, 2007 shouldnt need to, i never drain coolant when removing g/boxes off any car Quote Link to comment Share on other sites More sharing options...
Toucan Posted August 12, 2007 Share Posted August 12, 2007 Think the only reason you'd need to drain the coolant is due to taking off the radiator hoses so that you can tilt the engine back to pull the gearbox off. Im not aware of any other reason you would ahve to drain it for. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted August 12, 2007 Share Posted August 12, 2007 if you not takn motor out then nah. and if you have a spare drive shaft cut the front off it and use it to stop the oil coming out the back when removing (optional). good luck. Quote Link to comment Share on other sites More sharing options...
crispymk2 Posted August 12, 2007 Author Share Posted August 12, 2007 cheers... I'll need it![/i] Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 12, 2007 Share Posted August 12, 2007 A reason could be.. Sometimes when removing gbox the exhaust gets in the way, Usually down by the flange so ya just undo the flange.. But sometimes ya have to pull the manifold off to get the exhaust out of the way. If so the crossflow manifold middle bolt goes through a waterway. Undo this to get the gbox out and you will leak coolant. Just a thought. Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 12, 2007 Share Posted August 12, 2007 seems odd, if it is like you said meth, why not say remove exhaust too? Quote Link to comment Share on other sites More sharing options...
sholdowa Posted August 12, 2007 Share Posted August 12, 2007 It's not something I've ever worried about. The logic must be based around the movement of the engine around the mounts stressing the rad through the hoses. But then they're supposed to be a bit flexible anyway, aren't they. If you've got a pinto and / or type 9, then lowering the crossmember ( put a few longer bolts in ) saves having to take the engine out! Quote Link to comment Share on other sites More sharing options...
crispymk2 Posted August 12, 2007 Author Share Posted August 12, 2007 Yeah, they say to remove exhaust manifold too but my exhaust bend was out of the way enough for me to drop it out. Nearly crushed myself tho... The jack would only go so high and there wasnt enough clearance for me to lower it off my chest onto the ground... Had to slide myself out from under it! Fuck knows how I'm gonna get it back in again... might have to get it towed after all. *edit: i was using axle stands but the jack would only let me use them at a certain height... not silly enuf to get under the car with just a jack (anymore)... Quote Link to comment Share on other sites More sharing options...
davidian Posted August 12, 2007 Share Posted August 12, 2007 huh? cant you stick a block of wood or something on your jack? its my common practice lols Quote Link to comment Share on other sites More sharing options...
Raizer Posted August 12, 2007 Share Posted August 12, 2007 If so the crossflow manifold middle bolt goes through a waterway. Undo this to get the gbox out and you will leak coolant. No it doesn't. Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 12, 2007 Share Posted August 12, 2007 can you not jack the car up? Quote Link to comment Share on other sites More sharing options...
crispymk2 Posted August 12, 2007 Author Share Posted August 12, 2007 can you not jack the car up? Yeah, it was all good, I jsut underestimated the height of the bell housing... Not quite enuf room for me and the gearbox underneath to fully clear the chassis, ment I had to slide out from under the g/box rather than lowering it off my chest to the side, also limited room cause I had the jack (with a block of wood on it - davidian) supporting the end of the engine to take pressure of the mounts etc. Was a dodgy enuf operation as it was without adding wooden blocks to the mix... Quote Link to comment Share on other sites More sharing options...
davidian Posted August 12, 2007 Share Posted August 12, 2007 dodgy mixes ftmfw. when i was changing the steering rack i undid the mounts and held the engine up by jack and FOUR blocks of wood in between the two. dodgy is the way ftlols Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 12, 2007 Share Posted August 12, 2007 If so the crossflow manifold middle bolt goes through a waterway. Undo this to get the gbox out and you will leak coolant. No it doesn't. Hrm your right. It was the inlet manifold that had the bolt that went into a waterway not the exhaust manifold.extractors. Quote Link to comment Share on other sites More sharing options...
Raizer Posted August 12, 2007 Share Posted August 12, 2007 If so the crossflow manifold middle bolt goes through a waterway. Undo this to get the gbox out and you will leak coolant. No it doesn't. Hrm your right. It was the inlet manifold that had the bolt that went into a waterway not the exhaust manifold.extractors. Yeah its the inlet that your thinking of, it should have a stud not a bolt, and even with a bolt you wont loose coolant until you take the manifold off the head -the bolt/stud hole isn't open into the waterway Quote Link to comment Share on other sites More sharing options...
