escort mk1 Posted February 9, 2007 Share Posted February 9, 2007 Does anyone know where or if i can get a BDA 1600 for my mk1. Is there any for sale in NZ or if you know where you can import them from? And any info on bda's please??? Quote Link to comment Share on other sites More sharing options...
mark105 Posted February 9, 2007 Share Posted February 9, 2007 saw this the other day http://www.speedbitz.com/listing/680-ford_bda/ maybe if your rich? Quote Link to comment Share on other sites More sharing options...
escort mk1 Posted February 9, 2007 Author Share Posted February 9, 2007 shit....i didnt espect it to be that much. you can buy a mint twincam for that price! Quote Link to comment Share on other sites More sharing options...
sholdowa Posted February 9, 2007 Share Posted February 9, 2007 ...but would you trust a dry stumped oz engine?? I certainly wouldnt. Quote Link to comment Share on other sites More sharing options...
peteretep Posted February 9, 2007 Share Posted February 9, 2007 realistically looking at 30 grand + imo Quote Link to comment Share on other sites More sharing options...
escort mk1 Posted February 9, 2007 Author Share Posted February 9, 2007 Just found out that palmside in chch sells 2.0 BDA block for $6500 and the cam and crank pistons, pushrods and so on are also for sale. But dont know how orginal.... Quote Link to comment Share on other sites More sharing options...
peteretep Posted February 9, 2007 Share Posted February 9, 2007 it would all be proper stuff Quote Link to comment Share on other sites More sharing options...
Raizer Posted February 9, 2007 Share Posted February 9, 2007 With the $ involved buying a BDA you could just about build a BDT Quote Link to comment Share on other sites More sharing options...
escort mk1 Posted February 9, 2007 Author Share Posted February 9, 2007 Whats a BDT? Reallyl i just want to build a fast 1600 and keep it a original escort engine. Whats the best engine to go for? Quote Link to comment Share on other sites More sharing options...
Raizer Posted February 9, 2007 Share Posted February 9, 2007 The BDT engine was built for the failed RS1700T MK3 Escort group B rally car and ended up being used in the RS200. Its basically a 1800 turbo BDA, 250HP in street trim, and between 350 and 450HP in the rally cars. Personally i would (and did ) build up a 1700 crossflow (83.5mm bore) with a large "road/rally cam - Kent 234 or similar, decent port job and a pair of Webber/Dellorto 40s Quote Link to comment Share on other sites More sharing options...
thminiman Posted February 9, 2007 Share Posted February 9, 2007 waiste of dollars, do something else, Quote Link to comment Share on other sites More sharing options...
davidian Posted February 11, 2007 Share Posted February 11, 2007 $$ is not worth it except for the wow factor. go newer. go turbo Quote Link to comment Share on other sites More sharing options...
mikuni Posted February 12, 2007 Share Posted February 12, 2007 Nah, build a nice high revving modern NA engine. Ford have some cool motors around that you could use from what I have seen. For literally a fraction of the price you can have something that will be faster, more reliable and sound great. You won't have the old technology of the BDA, thats the only draw back. If you won't that you will have to spend the dollars. There no way around it. And the final product won't be as usable as with a newer motor. Quote Link to comment Share on other sites More sharing options...
davidian Posted February 12, 2007 Share Posted February 12, 2007 you could get a full race pinto for a fraction even. Id go for a duratec worked or even non-ford Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted February 12, 2007 Share Posted February 12, 2007 You better have really deep pockets BDA = $$$$$$$$$$$$$$$$$$$ http://www.wilcoxengines.demon.co.uk/ Alloy block, steel N/J lightweight crank, H section steel con rods, forged pistons, steel flywheel, twin paddle clutch, dry sump pump and pan, big valve head, latest spec cam carrier, 48 Weber carbs, air filter, electronic ignition kit and plug lead set. Fully assembled and dyno tested. £16750 (NZ$47,763) Complete engine kits : 2.0L kit Alloy block: £14900 (NZ$42,483) 1.6L kit steel block: £ 12600.00 (NZ$35,925) The good news is the conversion kit is cheaper.... BDR kits now available to convert your Ford Crossflow into a 1700cc 160bhp/170bhp engine: £7400 (NZ$21,089) Quote Link to comment Share on other sites More sharing options...
Bullitt Posted February 12, 2007 Share Posted February 12, 2007 Those prices dont work too well...why not buy the conversion kit, rebuild all the remaining bits of a kent and sell it for somewhere under 35k...seems like easy money Quote Link to comment Share on other sites More sharing options...
Raizer Posted February 12, 2007 Share Posted February 12, 2007 It would be cheaper to get all the bits from Burton's rather than Wilcox Quote Link to comment Share on other sites More sharing options...
mk5corty Posted February 12, 2007 Share Posted February 12, 2007 2.3 duratec ftw if powerful N/A is what your after, 250hp can be had out of a streetable motor. Quote Link to comment Share on other sites More sharing options...
CUL8R Posted February 12, 2007 Share Posted February 12, 2007 http://www.trademe.co.nz/Trade-Me-Motor ... 770498.htm That one of them?? Cheers,Chris Quote Link to comment Share on other sites More sharing options...
mk5corty Posted February 12, 2007 Share Posted February 12, 2007 thats an american turbo pinto. http://www.cosworth.com/shop_item.php?productid=426 there is the cosworth 250hp version but bear in mind that price is for all new parts and would be designed to last for a standard engines life. you could do nearly as well for much cheaper, like most modified engines. Quote Link to comment Share on other sites More sharing options...
